DT125 Posted September 13, 2015 Share Posted September 13, 2015 1234567890 Link to comment Share on other sites More sharing options...
Frank Bullitt Posted September 13, 2015 Share Posted September 13, 2015 It's all in the technical section of the forum, under FAQ's Link to comment Share on other sites More sharing options...
DT125 Posted September 13, 2015 Author Share Posted September 13, 2015 It's all in the technical section of the forum, under FAQ's 1234567890 Link to comment Share on other sites More sharing options...
Frank Bullitt Posted September 13, 2015 Share Posted September 13, 2015 I had a look but cant find anything Strange, I've just done a search and found at least 4-5 different thread. Try searching "fitting an fcd" or "vfcc". Link to comment Share on other sites More sharing options...
DT125 Posted September 13, 2015 Author Share Posted September 13, 2015 Strange, I've just done a search and found at least 4-5 different thread. Try searching "fitting an fcd" or "vfcc". 1234567 Link to comment Share on other sites More sharing options...
Ric Posted September 13, 2015 Share Posted September 13, 2015 Nearly every thread in here - http://www.mkivsupra.net/vbb/forumdisplay.php?64-Technical-Reference-amp-FAQs Link to comment Share on other sites More sharing options...
DT125 Posted September 13, 2015 Author Share Posted September 13, 2015 Nearly every thread in here - http://www.mkivsupra.net/vbb/forumdisplay.php?64-Technical-Reference-amp-FAQs 1234567890 Link to comment Share on other sites More sharing options...
Frank Bullitt Posted September 13, 2015 Share Posted September 13, 2015 can you send me the link mate Unfortunately not as my copy and paste doesn't work. I need to know pin pictures so which wire to cut , power supply and earth . also which vaccum pipe to cut for the turbos and which ones to block off Everything you require including pictures are in the threads contained in the link Ric kindly posted up. Good luck with your search Link to comment Share on other sites More sharing options...
Tricky-Ricky Posted September 13, 2015 Share Posted September 13, 2015 I thought somebody who was going to build a 1500BHP 7 second Supra would have more of a grasp of the simple stuff....oh well baby steps. You don't cut pipes to go BPU, you remove the cat and fit a restrictor ring or you will over-boost, you also cannot just cut a wire at the ECU to remove fuel cut, you will need what is known as a fuel cut defender, or a piggyback ECU. Link to comment Share on other sites More sharing options...
DT125 Posted September 13, 2015 Author Share Posted September 13, 2015 I thought somebody who was going to build a 1500BHP 7 second Supra would have more of a grasp of the simple stuff....oh well baby steps. You don't cut pipes to go BPU, you remove the cat and fit a restrictor ring or you will over-boost, you also cannot just cut a wire at the ECU to remove fuel cut, you will need what is known as a fuel cut defender, or a piggyback ECU. 1234567890 Link to comment Share on other sites More sharing options...
Frank Bullitt Posted September 13, 2015 Share Posted September 13, 2015 Has anyone called Hovis yet? Link to comment Share on other sites More sharing options...
DT125 Posted September 13, 2015 Author Share Posted September 13, 2015 Has anyone called Hovis yet? 1234567890 Link to comment Share on other sites More sharing options...
Tricky-Ricky Posted September 13, 2015 Share Posted September 13, 2015 Has anyone called Hovis yet? I think its a case of your sig being quite correct Link to comment Share on other sites More sharing options...
Frank Bullitt Posted September 13, 2015 Share Posted September 13, 2015 Uh oh, I foresee a temper tantrum Link to comment Share on other sites More sharing options...
Tricky-Ricky Posted September 13, 2015 Share Posted September 13, 2015 Uh oh, I foresee a temper tantrum Already in progress:d Link to comment Share on other sites More sharing options...
DT125 Posted September 13, 2015 Author Share Posted September 13, 2015 I thought somebody who was going to build a 1500BHP 7 second Supra would have more of a grasp of the simple stuff....oh well baby steps. You don't cut pipes to go BPU, you remove the cat and fit a restrictor ring or you will over-boost, you also cannot just cut a wire at the ECU to remove fuel cut, you will need what is known as a fuel cut defender, or a piggyback ECU. you must be a genius so all these peolpe spending money on boost controlers and fuel cut defencers all they need to do is fit a decat and restrictor ring ! I think you must tell them that they are wasting money on things they don't need . you genius Link to comment Share on other sites More sharing options...
Tricky-Ricky Posted September 13, 2015 Share Posted September 13, 2015 you must be a genius so all these peolpe spending money on boost controlers and fuel cut defencers all they need to do is fit a decat and restrictor ring ! I think you must tell them that they are wasting money on things they don't need . you genius 1234567890 Link to comment Share on other sites More sharing options...
Frank Bullitt Posted September 13, 2015 Share Posted September 13, 2015 1234567890 :rlol: Link to comment Share on other sites More sharing options...
Abz Posted September 14, 2015 Share Posted September 14, 2015 1234567890 Link to comment Share on other sites More sharing options...
The Raven Posted September 14, 2015 Share Posted September 14, 2015 Ok wtf was all that about Link to comment Share on other sites More sharing options...
Tricky-Ricky Posted September 14, 2015 Share Posted September 14, 2015 Ok wtf was all that about Our resident "I'm going to build a 1500BHP ...correction 1600BHP 7 second Supra, wanted to know which pipe to cut to make the turbos boost more (BPU) and which wire to cut to disable boost cut, so I advised him like this, "I thought somebody who was going to build a 1500BHP 7 second Supra would have more of a grasp of the simple stuff....oh well baby steps. You don't cut pipes to go BPU, you remove the cat and fit a restrictor ring or you will over-boost, you also cannot just cut a wire at the ECU to remove fuel cut, you will need what is known as a fuel cut defender, or a piggyback ECU." I know I shouldn't, but the little twerp gets on my nerves, anyway he didn't like my advice as you can see above and threw a tantrum LOL! Link to comment Share on other sites More sharing options...
The Raven Posted September 14, 2015 Share Posted September 14, 2015 Aww now i see Bravo Link to comment Share on other sites More sharing options...
Frank Bullitt Posted September 14, 2015 Share Posted September 14, 2015 Also he seemed to lack the ability to use the search function and use his eyes, when I called Hovis I think that may have been the proverbial straw. Twerp, so long since I have heard that word used. Really made me thanks Link to comment Share on other sites More sharing options...
Chris Wilson Posted September 14, 2015 Share Posted September 14, 2015 When I wanted to build a multi kilo watt transmitter I started with something in the milli watt range and got that working (and not without a lot of troublesome questions to my peers...). I then went bigger, and found more questions and let the smoke out of several larger devices. I now have a multi kilo watt transmitter that works. I strongly advise the original poster to get BPU working and understand how and why it all plugs together, technically! Had I gone in as a newbie on the radio forums and said I was going to build Rugby transmitting station in my back yard, and then went on to ask how to wire the mains plug, I would expect similar responses to those you see above. Editing my faux pas with silly numbers would probably see me ignored in the future. Please get even a tenuous grasp on reality! There are several here who can and will give meaningful advice on big power cars, but you need to prove maturity and eagerness to learn. We probably see enough tantrums in our home and work lives not to want to see them here, too Link to comment Share on other sites More sharing options...
Tricky-Ricky Posted September 14, 2015 Share Posted September 14, 2015 I fear that patient and eloquent little explanation will be totally wasted Chris, and go above his head, he seems to have a tenuous grasp of the Queens English at the best of times, and just another reason I have lost all patience. Link to comment Share on other sites More sharing options...
