anyone ever seen a brake caliper fracture around the bleed nipple?
Dave Carroll
As the title says really....
Decided to flush out the brake fluid and replace with some new stuff today (my all out comp spec brakes are waiting for next year) to get rid of what seemed like fluid boil at the last track day.
Afterall, the j specs with the pads and discs im using were fine and the front tyres were the limiting factor for now...
Well the fluid change wouldnt bleed properly...
I found the front left caliper had a huge fracture around the bleed nipple! And i mean it is hanging on by around a quarter of its circumference.
Good job i brought those uk specs back from Japan!
That is a major design flaw on a safety critical part if you ask me.
If there is one thing toyota got wrong in the 90s its these j spec calipers. They seize so easily, ive seen them fracture around the pads on the rears and now this....
Any common failures i should watch out for on the uk specs?
When they get old, the pad sliding pins in the calipers often become stuck. If they flare or bend, it means drilling the caliper out. Next time you change your pads, fir some Chris Wilson stainless caliper pins :)
Luckily my UK specs are in very good condition for now... came off a low mileage car in japan, but admittedly supposed to have been used fairly hard.
Chris has told me about his stainless steel rebuild kits for the UK specs so will be ordering them when the time comes :)
Yes, when I first brought my supra, every new car I buy I always do a service and change the brakes, so when I brought the supra I got on to change the front discs and pads and found both front calipers had cracked and leaking fluid near the bleed nipples where they have been over tighten, I'm lucky that I always do that on every new car I buy other wise I could of had a nasty accident
Just make sure you keep any eye on those pins, as by the time you realise it's a problem it will be too late. Better to replace them sooner than later :)
