Tricky-Ricky Posted October 12, 2015 Share Posted October 12, 2015 So all the front panel switches are zeroed, and AVV overall is adjusted to zero? If the std ECU uses both MAP and MAF that may be your problem, do you know just how the std ECU uses these signals for scaling its own fuelling maps? Link to comment Share on other sites More sharing options...
walkerstrider Posted October 13, 2015 Author Share Posted October 13, 2015 No idea mate, I don't think anyone else has had this kind of issue. When I get home from work I'm gonna redo all the wiring as I don't know where else to look. If that doesn't work I'm stuck! Link to comment Share on other sites More sharing options...
Shane Posted October 13, 2015 Share Posted October 13, 2015 As far as I know, the NA uses just MAP. When I was messing about with a supercharger on mine, I needed to put a one way valve inline with the MAP sensor because the moment the sensor saw boost the engine cut out, not that that really helps your situation. I can't think what you mean about a MAF sensor behind the intake? Unless there are some variations, certainly the NAs I have owned and the wifes looks only to have MAP. Link to comment Share on other sites More sharing options...
walkerstrider Posted October 13, 2015 Author Share Posted October 13, 2015 My bad, it's an air temp sensor not maf. So it is just map. Link to comment Share on other sites More sharing options...
Tricky-Ricky Posted October 13, 2015 Share Posted October 13, 2015 I know its obvious but are you sure the polarity of the wires is correct? and have you selected the type of sensor on the main menu? Link to comment Share on other sites More sharing options...
walkerstrider Posted October 13, 2015 Author Share Posted October 13, 2015 (edited) I've just rewired the emanage to see if I've missed something but it's no different. Here's a link to show the data log. Maybe it will help. Edited October 13, 2015 by walkerstrider (see edit history) Link to comment Share on other sites More sharing options...
walkerstrider Posted October 13, 2015 Author Share Posted October 13, 2015 And the Afr gauge Link to comment Share on other sites More sharing options...
walkerstrider Posted October 13, 2015 Author Share Posted October 13, 2015 Thanks for all your help guys. I don't know what else to try. Link to comment Share on other sites More sharing options...
Tricky-Ricky Posted October 13, 2015 Share Posted October 13, 2015 It says the videos are private. Link to comment Share on other sites More sharing options...
walkerstrider Posted October 13, 2015 Author Share Posted October 13, 2015 Not sure how else to upload them as their on my phone. Link to comment Share on other sites More sharing options...
walkerstrider Posted October 13, 2015 Author Share Posted October 13, 2015 Should be able to watch them now. Sorry about that. My computer skills aren't the best! Link to comment Share on other sites More sharing options...
Tricky-Ricky Posted October 13, 2015 Share Posted October 13, 2015 OK straight away I can see that there is something really wrong with the airflow input output, its not changing at all so there is some problem with the signal, so I would recheck you have the wiring and the settings correct, I suspect this is the problem, especially since it runs OK with the MAP sensor plugged back into the std ECU. this is also verified by the lambda showing as rich as 9 AFR at idle, I wouldn't let it idle too long at that rich mixture. Link to comment Share on other sites More sharing options...
walkerstrider Posted October 14, 2015 Author Share Posted October 14, 2015 Would using the Greddy 3bar map sensor make any difference. I've checked wires and settings over and over! Unless the Greddy instructions are wrong it's wired as it should be. Link to comment Share on other sites More sharing options...
Tricky-Ricky Posted October 14, 2015 Share Posted October 14, 2015 I am wondering if you have the signal and earth of the MAP sensor mixed up, I am not sure with the blue that you can use the Greddy sensor to scale the std ECU, I will have to check. Link to comment Share on other sites More sharing options...
walkerstrider Posted October 14, 2015 Author Share Posted October 14, 2015 I am wondering if you have the signal and earth of the MAP sensor mixed up, I am not sure with the blue that you can use the Greddy sensor to scale the std ECU, I will have to check. Only wires I have for airflow is input and out put mate. Wired to pin 62. I have tried swapping these round but no joy. The only grounds are ecu ground and injector ground. Link to comment Share on other sites More sharing options...
walkerstrider Posted October 15, 2015 Author Share Posted October 15, 2015 Finally sorted this out! Turns out the actual emanage harness was faulty! No wonder it wasn't reading airflow! Thanks again for all your help guys. Link to comment Share on other sites More sharing options...
berg Posted October 15, 2015 Share Posted October 15, 2015 Good job must be a relief Time to clear that soot out the exhaust Link to comment Share on other sites More sharing options...
walkerstrider Posted October 15, 2015 Author Share Posted October 15, 2015 Relief is an understatement! Spent 3 weeks looking for this fault! Thing that really pisses me off is I bought it in good faith of another supra owner. Lesson learned I think. Link to comment Share on other sites More sharing options...
trebor69 Posted October 15, 2015 Share Posted October 15, 2015 I recently bought a cat d off a supra owner ......yeah we keep learning these lessons:thumbdown: Glad you've finally nailed it down mate Link to comment Share on other sites More sharing options...
Tricky-Ricky Posted October 15, 2015 Share Posted October 15, 2015 Glad you finally got it sorted, its always the simple stuff that catches us out. Link to comment Share on other sites More sharing options...
walkerstrider Posted October 15, 2015 Author Share Posted October 15, 2015 I almost feel stupid! At least it wasn't my poor wiring skills. Link to comment Share on other sites More sharing options...
