Emanage problem
walkerstrider
What fuel pump do you have fitted? When the ignition is turned to position 2 and the car is unimmobilised you should hear the fuel pump prime.
Not sure it will be immobiliser though if it's cranking over.
Have you checked all the earth points including the stock ECU?
I had the same problem on my emanage ultimate on my old na-t
Ran like an absolute dog, timing etc was fine
2 of the wires (map sensor, temp sensor) were wired wrong
The instructions i had were incorrect which made the 2 wires the wrong way round
I would double check all wires match the diagram and even try and source another diagram online, thats what i done
  • 2 weeks later...
Any help appreciated. I've just fitted an Afr wideband gauge to see just how rich I was running.
With the emanage hooked up it runs at 9.6 at idle and really runs terrible up to about 3000 revs
With the stock ecu it runs at around 14.5 at idle. And runs so much smoother although it is a little lumpy at tickover. And with the emanage hooked up the engine light stays on, with the stock ecu it doesn't.
Would this be down the a map already on the emanage or something else as I'm a little stuck and need it back on the road asap! Thanks in advance.
Edited by walkerstrider (see edit history)
Its obviously down to the emanage, but I would suspect something is not set up or connected right with that AFR reading, if it was purely the emanage map the std ECU would be fighting it a bit more than that, as the emanage is not able to keep closed loop AFRs that low, check the MAF and MAP connection's.
Hi walkerstrider, I wish i could help you, but this area of the Supras to me is the most complicated and most important on the car, i just had an NA/T carried out by a experienced professional, but for the mapping and importance of getting it spot on, especially for mpg and performance, is why i did not fit the kit DIY. I would consult a pro and get it sorted as even if you do get it running seemingly ok, you may still have mpg issues or running lean which could damage your engine. Good luck anyway.
It'll probably be barely running at that AFR, far too rich. If you take a data log of it, recording everything, and post it up here, it'll help with diagnosis. See what the E-Manage is seeing and what it thinks it should do with it.
Yeah it virtually stalls with the emanage hooked up. I don't think it's reading airflow as I'm getting very low voltage on the output wire but 3.5 on input. On the emanage it reads. 1 input voltage and 0 output! Something strange though, if I disconnect and connect volt meter to pin 62 on ecu it reads 4.5 volts? Surely this should read 0 volts until it's connected. I'm lost! Double checked this is correct wire for ar connection. Seems to be according to every shematic I've seen. Runs fine if I disconnect ar wire but obviously I get the error code on emanage. I get this even with it hooked up tho. Maybe it's the wrong wire but don't know what other wire to try.
OK so I've tried a different emanage with a safe map on and still exactly the same problem! I've also tried different jumper settings rotary switch settings. Nothing seems to change anything. The airflow is connected to pin 62 on the ecu. White going to sensor and green going to ecu. If I leave the emanage connected apart from airflow wire it runs fine. I am completely lost!!
So its connected properly, the jumpers are set correctly and the rotary switches have been tried in different positions, have you tried adjusting the overall fuel trim setting? given that you have tried another unit and disconnecting the emanage and allowing the std airflow to scale things works fine.
This would suggest that its down to the emanage settings.
As I have never owned an N/A can you tell me the airflow setup IE MAP MAF or both?
I've not adjusted any thing on the fuel trim settings. Literally just exported a safe map which up until the higher rev range all values are zeroed which I understand means the stock ecu settings will apply. It works on the map sensor but there is also a maf probe which pushes in just behind air intake. I changed this for a different unit also but no difference.
