jza800 Posted September 9, 2015 Share Posted September 9, 2015 i have bourgt a leather cover set to my supra, i can see there is a how to guide inhere.. bout that is on a old leather seats, but mine is not leather, are there some that have some pictures off how you did the headrest when it is not leather??? Link to comment Share on other sites More sharing options...
listy Posted September 9, 2015 Share Posted September 9, 2015 Um.......the same way. The material doesn't matter as far as I am aware, the process is the same. Link to comment Share on other sites More sharing options...
jza800 Posted September 9, 2015 Author Share Posted September 9, 2015 Um.......the same way. The material doesn't matter as far as I am aware, the process is the same. Not all the same, have taken the seat fabric apart with no problem, but the headrest give me some problems as it is glued on the foam rubber. the problem is i have tried on the one of the headrest to take the fabric of, but it is taken some off the foam rubber with it, in particular about where the stitching is.. so if someone have a guide where they have taken the headrest apart. I would be grateful Link to comment Share on other sites More sharing options...
Mk4Gaz Posted September 9, 2015 Share Posted September 9, 2015 Just fit the leather cover over the fabric Link to comment Share on other sites More sharing options...
jza800 Posted September 9, 2015 Author Share Posted September 9, 2015 I have bourgt the supra mkiv genuine leather covers from this company, just if someone can confirm that the cover can go over the fabric ?? Link to comment Share on other sites More sharing options...
jza800 Posted September 9, 2015 Author Share Posted September 9, 2015 Just fit the leather cover over the fabric have you tried that since you say that? just what to be sure instaed of trie and brake the stitching in the cover Link to comment Share on other sites More sharing options...
Mk4Gaz Posted September 9, 2015 Share Posted September 9, 2015 Yes, it should be fine. I've done it before, on different seats. It'll be tight, but a tip is to put a carrier bag, or bin liner over the original head rest, and slide the cover over it. The plastic will stop the new head rest gripping the material, and make it much easier to get on Link to comment Share on other sites More sharing options...
jza800 Posted September 10, 2015 Author Share Posted September 10, 2015 thanks for the advise mk4gaz i will follow your advise and hope i can get in on with not so much force Link to comment Share on other sites More sharing options...
