D2 and UK spec brake help
Supraleeturbo
I'm thinking of selling my UK spec front break set up and buying a set of the 6 pot d2 now.
Now my question is what size is the UK spec disc as I'd like to keep that size for the d2 so when it come to replacing later on down the line I'm not spending millions of pounds on discs
And secondly how much are my uk set worth disc and calipers are spot on but would need new pads or may come with new porter fields
Many thanks caps
Lol cheers bud so if I went for the 330mm then where would I get disc from later on as I can't find 330 disc on there own anywhere ?
Sorry mate I've no idea, I stuck with the stock UK set up which I couldn't fault other than they don't look
as bling as AP's, Brembo's etc
Common sence tells me if your buying a d2 kit, surely you'd get replacement discs from them.
Who supply d2 with the discs? Are they ap, brembo, alcon?
Do you really need bigger/ better brakes for cruising car parks?:D
Yer and I have now found that after a couple of call that driftworks do them , and hell yer got to look good parked up lol if for more when I race the saxso lol
