T2 MSW Posted September 7, 2015 Share Posted September 7, 2015 (edited) Turns out the leak I have been chasing on my car is not power steering but the clutch line. Ive disconnected the line cleaned it up and resealed it toped up with fluid. Leak sorted I then went to bleed the clutch. Cutch was perfectly fine before the leak. Ive put a litre of fluid through it so am sure there is no air in the system. no matter what I do the clutch pedal can be pushed up and down with ease Ive tried both putting a pipe on the slave bleed nipple, submersing the other end in fluid and pumping the pedal. Eventually its just fluid that comes out (not as much as I would expect). But no pedal at all. Also tried bleeding it line a brake which has made no difference. Im thinking the rubber seal has gone and I need to replace the master cylinder?!?! The only other thing I can think this morning is there is a small percentage the fluid I put in is gearbox oil and not brake fluid as the bottles are identical. I can't check this right now as I just thought about it this morning. Know it would need flushing and changing but can't see this being the issue. Edited September 7, 2015 by T2 MSW (see edit history) Link to comment Share on other sites More sharing options...
