Rob_Mitchell Posted February 9, 2016 Share Posted February 9, 2016 Changing the auxiliary belt will be fun lol. Nice build Quote Link to comment Share on other sites More sharing options...
little num Posted February 9, 2016 Share Posted February 9, 2016 coming along nicely there tim, you do a great job I must say. not like that abortion car david P's Quote Link to comment Share on other sites More sharing options...
David P Posted February 9, 2016 Share Posted February 9, 2016 (edited) coming along nicely there tim, you do a great job I must say. not like that abortion car david P's Hmmm, it smells like the Club vagina Deranged Pikey is about? Maybe it's a fluke that my "abortion" of a car happens to be the most popular Supra in the Club? http://www.mkivsupra.net/vbb/vbpicgallery.php Edited February 13, 2016 by David P (see edit history) Quote Link to comment Share on other sites More sharing options...
TBDevelopments Posted February 9, 2016 Author Share Posted February 9, 2016 Cheers guys Just plugging away on spare hours i get between customer projects Quote Link to comment Share on other sites More sharing options...
little num Posted February 13, 2016 Share Posted February 13, 2016 (edited) Hmmm, it smells like the Club vagina is about? Least im useful being a vagina , aint you gone to that weirdo hospital yet. Bring it on DB then see how long it lasts before it blows up or sets on fire Edited February 13, 2016 by little num (see edit history) Quote Link to comment Share on other sites More sharing options...
TBDevelopments Posted April 2, 2016 Author Share Posted April 2, 2016 Havent had much chance to play with the supra but the apexi commander screen is starting to come on nicely Tim TBDevelopments Quote Link to comment Share on other sites More sharing options...
supra_ufo Posted April 2, 2016 Share Posted April 2, 2016 that looks awesome Tim (if only i knew what it did) Quote Link to comment Share on other sites More sharing options...
TBDevelopments Posted April 2, 2016 Author Share Posted April 2, 2016 The commander unit is normally a hand held controller for the apexi powerfc standalone ecu. The display allows me to tweak the map in realtime, but mainly it can display anything the ecu is seeing. I typically use it for knock and intake temps. Quote Link to comment Share on other sites More sharing options...
drift_bear Posted April 2, 2016 Share Posted April 2, 2016 Is this like a toucan display but for the apexI unit then? Quote Link to comment Share on other sites More sharing options...
TBDevelopments Posted April 2, 2016 Author Share Posted April 2, 2016 Yeah basically. There normally like this, but ive replaced the screen for a white on black lcd screen so it matches the defi gauges and boost controller at night Quote Link to comment Share on other sites More sharing options...
drift_bear Posted April 2, 2016 Share Posted April 2, 2016 Didn't know you could remove the screen from the hand controller! Where have you mounted the controller then? Quote Link to comment Share on other sites More sharing options...
TBDevelopments Posted April 2, 2016 Author Share Posted April 2, 2016 You cant easily. It involves cutting the circuit board and running a cable. Ill mount the control buttons in the centre dash pocket. Quote Link to comment Share on other sites More sharing options...
Sheefa Posted April 3, 2016 Share Posted April 3, 2016 Looks lovely Tim, great fabrication work. Quote Link to comment Share on other sites More sharing options...
TBDevelopments Posted April 3, 2016 Author Share Posted April 3, 2016 Thanks Quote Link to comment Share on other sites More sharing options...
TBDevelopments Posted May 2, 2016 Author Share Posted May 2, 2016 works been busy again so i've been doing a few ideas for the chargecooler tank at night time. Thanks to Burna from this forum for helping me with Solidworks and countless hours on the tutorials i've taught myself to 3D Model. Quite Proud of myself seeing i'm far from computer literate. This is what I've come up with for the top water chamber. The top side will house an aluminum filler cap. Going to double check my measurements then wait months for the machine shop to actually make it haha. Tim TB Developments Quote Link to comment Share on other sites More sharing options...
Burna Posted May 3, 2016 Share Posted May 3, 2016 Looks good mate, well done Quote Link to comment Share on other sites More sharing options...
TBDevelopments Posted May 3, 2016 Author Share Posted May 3, 2016 cheers mate Tim TB Developments Quote Link to comment Share on other sites More sharing options...
TBDevelopments Posted August 1, 2016 Author Share Posted August 1, 2016 Had to tweak the design slightly to give room for the top radiator hose, but all the cnc work is now done Tim TBDevelopments Quote Link to comment Share on other sites More sharing options...
Sheefa Posted August 1, 2016 Share Posted August 1, 2016 Awesome work mate. Well done Quote Link to comment Share on other sites More sharing options...
Luxluc Posted August 1, 2016 Share Posted August 1, 2016 Great Tim Quote Link to comment Share on other sites More sharing options...
bignum Posted August 1, 2016 Share Posted August 1, 2016 Nice mate. Quote Link to comment Share on other sites More sharing options...
mellonman Posted August 2, 2016 Share Posted August 2, 2016 (edited) Looking good Tim, Love anything cnc made must be proud for a first timer . Hope you dont end up with a over heating problem due to air flow around the block, are you putting in another radiator to cool the water? Edited August 2, 2016 by mellonman (see edit history) Quote Link to comment Share on other sites More sharing options...
TBDevelopments Posted August 2, 2016 Author Share Posted August 2, 2016 Thanks guys. Should be ok but time will tell Yes chargecooler gets its own radiator. Ill get some pictures with the core all welded up. Means I can start on designing the end tanks Quote Link to comment Share on other sites More sharing options...
TBDevelopments Posted April 22, 2017 Author Share Posted April 22, 2017 pulled the modified whifbitz decats and fitted my own along with the new tbdev exhaust system Quote Link to comment Share on other sites More sharing options...
marbleapple Posted April 22, 2017 Share Posted April 22, 2017 Looking good! Quote Link to comment Share on other sites More sharing options...
