Harmonic balancer
Guest suprageek
As scooter says you must be missing the woodruff key, you can get them from a motor bike spares shop for about £1 but you would nned the orignal to compair so makes that a moot point,
Is it a stock balancer as I have heard after market ones need opening up to even get on
Guest suprageek
I think it's on, gonna compare the original on how far it sits out from the lower timing cover to be sure it's all the way on, looks about right it's only sitting 3-4 mm out
Guest suprageek
It's not goosed it does need putting on with the bolt and pulling off with a puller, it's on tight it's going nowhere, when I said it slid on and off easily I didn't mean by hand
Edited by suprageek (see edit history)
