Paul Whiffin Posted March 31, 2003 Share Posted March 31, 2003 Hi chaps, Does anyone know what the weight distribution front and rear is on a MK4 TT? Also does anyone know the height of the centre of gravity is as well? Link to comment Share on other sites More sharing options...
Nathan Posted March 31, 2003 Share Posted March 31, 2003 51%F/49%R Can't help on the rest mate. Sorry. Nathan TDI PLC Link to comment Share on other sites More sharing options...
Supra Pilot Posted March 31, 2003 Share Posted March 31, 2003 Originally posted by Paul Whiffin Hi chaps, Does anyone know what the weight distribution front and rear is on a MK4 TT? Also does anyone know the height of the centre of gravity is as well? I assume this does not take into consideration if 'Steve W' will be in the car or not, as that will be one hell of a split I imagine:innocent: Link to comment Share on other sites More sharing options...
eyefi Posted March 31, 2003 Share Posted March 31, 2003 Originally posted by Nathan 51%F/49%R Can't help on the rest mate. Sorry. Nathan TDI PLC r them numbers for stock suspension?? Link to comment Share on other sites More sharing options...
Syed Shah Posted April 1, 2003 Share Posted April 1, 2003 51% Front and 49% rear is for the NA. It is 52% v 48% on a TT. Link to comment Share on other sites More sharing options...
Steve W Posted April 1, 2003 Share Posted April 1, 2003 Is it the same Manual/Auto ? ? (Gearbox etc) what about 'spec' ie. A/C, 'lec seats,active spoiler, etc etc (not a LOT of actual 'weight' I suppose ?) Link to comment Share on other sites More sharing options...
Need4Speed Posted April 3, 2003 Share Posted April 3, 2003 Has anybody put a corner-weight gauge on to verify this? r them numbers for stock suspension?? Suspension does not affect it. Link to comment Share on other sites More sharing options...
Guest Martin F Posted April 3, 2003 Share Posted April 3, 2003 Well i've just recently purchased the Autocar with the original TT roadtest in it and they quote the weight distribution as 55% Front and 45% rear. Not sure if they're right\wrong or whatever, but they are certainly different to the above. Link to comment Share on other sites More sharing options...
Alex Posted April 3, 2003 Share Posted April 3, 2003 Originally posted by John Packham Has anybody put a corner-weight gauge on to verify this? Suspension does not affect it. So what's corner weighting about??? I thought that adjusted the weight over each wheel?? Link to comment Share on other sites More sharing options...
Steve W Posted April 3, 2003 Share Posted April 3, 2003 1 'source' = Link to comment Share on other sites More sharing options...
Steve W Posted April 3, 2003 Share Posted April 3, 2003 2nd 'source' = Link to comment Share on other sites More sharing options...
Steve W Posted April 3, 2003 Share Posted April 3, 2003 3rd = Link to comment Share on other sites More sharing options...
Steve W Posted April 3, 2003 Share Posted April 3, 2003 4th = Link to comment Share on other sites More sharing options...
Alex Posted April 3, 2003 Share Posted April 3, 2003 Wet or Dry weight??? That fuel tank is pretty vast the weight must affect the distribution. I would guess its about 53/47 dry and 51/49 wet....is that fair? Link to comment Share on other sites More sharing options...
Need4Speed Posted April 3, 2003 Share Posted April 3, 2003 Alex The sum of the two front corner weights expressed as a percentage of the all-up weight should be 53% and the rear 47%. To prove the point, if anyone has a suitable corner-weight gauge, they should be able to show approx 415kg on each front wheel and 368kg on each rear. The car won't be perfectly balanced left/right, but the principle is there. Generally the weight includes fluids but not fuel in the tank. A full tank would add 60kg+ to the all-up weight and, bearing in mind the position of the tank, about 30kg or so to each rear corner weight. An easy alternative would be to put the front wheels on a weigh bridge and then the rears. Link to comment Share on other sites More sharing options...
Piran Posted April 3, 2003 Share Posted April 3, 2003 Originally posted by Alex Holdroyd Wet or Dry weight??? That fuel tank is pretty vast the weight must affect the distribution. But only briefly Link to comment Share on other sites More sharing options...
Gordon F Posted April 3, 2003 Share Posted April 3, 2003 Originally posted by John Packham Suspension does not affect it. Err..yes it does. If you change the spring rate, or lower or raise the ride height at one end, that will affect the weight distribution, which should always be measured dry...... Link to comment Share on other sites More sharing options...
Need4Speed Posted April 4, 2003 Share Posted April 4, 2003 Err..yes it does only by a very small amount Link to comment Share on other sites More sharing options...
Branners Posted April 4, 2003 Share Posted April 4, 2003 also all the mods that are done to a car will change it as well. The cats weigh a lot compared to a standard downpipe, adding a FMIC will bring the weight forward, removing the aircon will shift it back, stereo system in the boot throws it out. UK and import might also be different due to different size petrol tanks. Best bet is to get along to a bookatrack day at some point and ask to use their weight measuring equipment. JB Link to comment Share on other sites More sharing options...
Need4Speed Posted April 4, 2003 Share Posted April 4, 2003 It's all small items though compared to the engine, transmission, diff, and even the wheels. 1% is about 16kg, thats a hell of a big sub. Link to comment Share on other sites More sharing options...
Steve W Posted April 4, 2003 Share Posted April 4, 2003 I can only JUST lift my subs/amp/box ! ! so, I'd guess about 30-40 kilos ! ! but, that's balanced quite nicely by my stomach in the front !!! SEE, I try my hardest to keep the weight ratio right:) Link to comment Share on other sites More sharing options...
Need4Speed Posted April 4, 2003 Share Posted April 4, 2003 Does anyone know what the weight distribution front and rear is on a MK4 TT? Paul, what's behind all this, now you've got a discussion going? I can only JUST lift my subs/amp/box so, I'd guess about 30-40 kilos ! ! ! ! That's about 7BHP used just to shift, let alone switch it on. Link to comment Share on other sites More sharing options...
Steve W Posted April 5, 2003 Share Posted April 5, 2003 OOOH, I've never heard anyone's Booomy-Blaster being rated in Horse=Power before ! ! ! That's got quite a nice 'ring' to it..... "I've got a 45 Horse-Power Stereo......" [what about turbo-ing it, or NOStereo ? ? ] Link to comment Share on other sites More sharing options...
