Dipped bulb issue
pf85
Sidelights - work ok
Main beams - work ok
Fog lights - work ok
Dipped beams - drivers dipped light works ok but the passenger light only illuminates about 20% of what it should and it also causes the two main beams to illuminate about 10%
I swapped the dipped bulbs around and did not make any difference but rules out any issue with the bulb. Sounds like a bad connection somewhere but I don't see anything obvious and there doesn't seem to be anything loose.
Any ideas before I take it to a mechanic tomorrow??
There are running or driving lights I think they are called, on the car which have a yellow output(not sure if this is standard or someone has put yellow bulbs in to use in the fog), does anyone know can I just swap these over with my dipped bulbs to cover me tonight till I get a look at it tomorrow?
