Richardsu Posted September 3, 2015 Share Posted September 3, 2015 Hi, I am new to all things to do with cars but am doing a great job sofar so i have had a guest what they are. ) can someone tell me what the parts are called and what they do in the pic. The car is 1993 supra 3.0 TT 2JZ GTE Auto http://imgur.com/MOQ54qQ 1: Looks like a smaller & thiner radiator but not sure what is for 2: I think its something to do with power steering fluid/pump 3: Looks like the fan for the small radiator Thanks Link to comment Share on other sites More sharing options...
Tricky-Ricky Posted September 3, 2015 Share Posted September 3, 2015 Hi, I am new to all things to do with cars but am doing a great job sofar so i have had a guest what they are. ) can someone tell me what the parts are called and what they do in the pic. The car is 1993 supra 3.0 TT 2JZ GTE Auto http://imgur.com/MOQ54qQ 1: Looks like a smaller & thiner radiator but not sure what is forAircon rad 2: I think its something to do with power steering fluid/pumpYes! power steering fluid cooler 3: Looks like the fan for the small radiatorYes! auxsilary cooling fan, comes on with aircon. Thanks ... Link to comment Share on other sites More sharing options...
Richardsu Posted September 3, 2015 Author Share Posted September 3, 2015 Thanks so much tricky, well thats why my aircon dont work with all that rust Link to comment Share on other sites More sharing options...
Benjy Posted September 3, 2015 Share Posted September 3, 2015 1. Air con condenser. 2. PAS cooler. 3. Big ass fan. Link to comment Share on other sites More sharing options...
Richardsu Posted September 5, 2015 Author Share Posted September 5, 2015 Well after fitting a new intercooler and radiator and seeing as the Air con is rusted up, i was thinking of removing the Air con fan & radiator out all together so i would like to know can i do this and just pull out the pipes to the engine for the air con radiator?? Link to comment Share on other sites More sharing options...
Boxertricks Posted September 6, 2015 Share Posted September 6, 2015 Yes mate, if it's not working you can remove your air con condenser and lines. If you want to remove it completely- the pulley bellow your PAS pump is your aircon compressor, this can also be removed. But there are other things you'd need to do to remove that though so it's a bit more involved- run a shorter belt and use a bracket to stabilize the PAS pulley/pump. You can use the front of your old compressor for this though, remove it from your compressor and use it to act as a bracket. Link to comment Share on other sites More sharing options...
Dnk Posted September 6, 2015 Share Posted September 6, 2015 I'd replace the cross member at the same time Link to comment Share on other sites More sharing options...
