Guest Pinhead Posted August 29, 2015 Share Posted August 29, 2015 Hi 1) How much does it cost for a cam-belt change on a turbo at a garage 2) Also what parts need to be changed 3) what part should you change at the same time . . Pin Quote Link to comment Share on other sites More sharing options...
TT Paul Posted August 29, 2015 Share Posted August 29, 2015 Lee p at srd pm him. Quote Link to comment Share on other sites More sharing options...
Swampy442 Posted August 29, 2015 Share Posted August 29, 2015 Just the belt can be changed, maybe the tensioner, pulley and water pump depending on condition but you can just get away with just the belt. Quote Link to comment Share on other sites More sharing options...
Scooter Posted August 29, 2015 Share Posted August 29, 2015 (edited) 1) not sure and depends on 2) 2) needs - the belt! 3) Possibles/niceties, crank pulley if original, cambelt idler wheel, aux belt, coolant change, water pump (I personally wouldn't do it til it needed it but then I'd be diying so happy to go through the labour twice - it would cost you as much in labour if it went a year later, so may be worth considering) As you are new I'm going to assume you are preparing to carry this out on any new car you buy? Not that I'm saying at all that you shouldn't do it but the supra engine is non interference and so no engine damage will result from a cambelt snapping. Basically you don't have to rush, you won't find any threads on belt failures. Edited August 29, 2015 by Scooter (see edit history) Quote Link to comment Share on other sites More sharing options...
Guest Pinhead Posted August 29, 2015 Share Posted August 29, 2015 HI thanks for replies it's nice to know that if the belt goes it does not take the engine with it still looking at that white one on ebay and after doing a bit of research i have found out a bit more about it , i know i have asked this before and as you have looked at it what price would you pay for it . . pin Quote Link to comment Share on other sites More sharing options...
Alex_GT Posted August 29, 2015 Share Posted August 29, 2015 the supra engine is non interference and so no engine damage will result from a cambelt snapping. Basically you don't have to rush, you won't find any threads on belt failures. Forgive me if I sound like an asshole, but is any part of the above statement true? I thought belt driven non-interference engines were virtually non-existent? Especially on road cars. Also, just because it's non-interference I thought if the belt failed it still damages other components? Quote Link to comment Share on other sites More sharing options...
Scooter Posted August 29, 2015 Share Posted August 29, 2015 HI thanks for replies it's nice to know that if the belt goes it does not take the engine with it still looking at that white one on ebay and after doing a bit of research i have found out a bit more about it , i know i have asked this before and as you have looked at it what price would you pay for it . . pin Depends what you've found I'll presume it's good! I'd have happily paid the original eBay ad price, but no way I'd personally pay over £10k for this. Have you seen it in the flesh yet? Quote Link to comment Share on other sites More sharing options...
Scooter Posted August 29, 2015 Share Posted August 29, 2015 Forgive me if I sound like an asshole, but is any part of the above statement true? I thought belt driven non-interference engines were virtually non-existent? Especially on road cars. Also, just because it's non-interference I thought if the belt failed it still damages other components? They are virtually non existent on modern cars as they are less efficient and everything is about efficiency these days. I think the vvti supras are interference though. There are no documented belt failures I can remember so no hard evidence of no damage but I've rotated a few cranks now with no cambelt in place and no lock up ie Pistons meeting valves. The belt could take out the tensioner or plastic covers etc. Quote Link to comment Share on other sites More sharing options...
Alex_GT Posted August 29, 2015 Share Posted August 29, 2015 I think the vvti supras are interference though. What is the engine code in the VVTi models? Quote Link to comment Share on other sites More sharing options...
Ric Posted August 30, 2015 Share Posted August 30, 2015 You can easily tell apart a VVTI to none VVTi, the VVTI's have a lump on the front of the nearside/intake camshaft which you can see with the spark plug cover. I dont know the specific engine code, but it's still a 2jz-gte. None VVTI VVTI. If you're going to the trouble of taking the belt off, id replace the water pump, tensioners and the crank pulley if its not new. Quote Link to comment Share on other sites More sharing options...
Chris Wilson Posted August 30, 2015 Share Posted August 30, 2015 I charge £150 plus VAT labour for a cam belt change. No extra labour to change tensioner or tensioner pulley. £20 extra to change the water pump. Quote Link to comment Share on other sites More sharing options...
