kevin smith Posted August 25, 2015 Share Posted August 25, 2015 Hi where are the correct jacking points, as it am not sure. many thanks. Quote Link to comment Share on other sites More sharing options...
Gaz6002 Posted August 25, 2015 Share Posted August 25, 2015 The search function reveals all: http://www.mkivsupra.net/vbb/search.php?searchid=5108140&pp=&page=3 Quote Link to comment Share on other sites More sharing options...
Frank Bullitt Posted August 25, 2015 Share Posted August 25, 2015 The search function reveals all: http://www.mkivsupra.net/vbb/search.php?searchid=5108140&pp=&page=3 The search function reveals... Sorry - no matches. Please try some different terms?! I find that very hard to believe Quote Link to comment Share on other sites More sharing options...
Gaz6002 Posted August 25, 2015 Share Posted August 25, 2015 The search function reveals... Sorry - no matches. Please try some different terms?! I find that very hard to believe Works on my machine. I only typed 'jacking points' into the search bar. Quote Link to comment Share on other sites More sharing options...
mattdavies Posted August 25, 2015 Share Posted August 25, 2015 Works on my machine. I only typed 'jacking points' into the search bar. If you do that there is a good thread with pictures of the underside of the car with dodgy MS Paint arrows on them Quote Link to comment Share on other sites More sharing options...
Gaz6002 Posted August 25, 2015 Share Posted August 25, 2015 If you do that there is a good thread with pictures of the underside of the car with dodgy MS Paint arrows on them Quote Link to comment Share on other sites More sharing options...
Frank Bullitt Posted August 25, 2015 Share Posted August 25, 2015 Works on my machine. I only typed 'jacking points' into the search bar. Obviously a MAC thing Quote Link to comment Share on other sites More sharing options...
mattdavies Posted August 25, 2015 Share Posted August 25, 2015 http://www.mkivsupra.net/vbb/showthread.php?213485-jacking-points-bending-damaged&highlight=jacking+points Thread with MS Paint Arrow Pictures Quote Link to comment Share on other sites More sharing options...
Chris Wilson Posted August 25, 2015 Share Posted August 25, 2015 http://www.mkivsupra.net/vbb/showthread.php?213485-jacking-points-bending-damaged&highlight=jacking+points Quote Link to comment Share on other sites More sharing options...
Chris Wilson Posted August 25, 2015 Share Posted August 25, 2015 I would *STRONGLY recommend you do not jack up on the sill points, use the front crossmember and under the middle of the diff at the back. Quote Link to comment Share on other sites More sharing options...
JayJay1374 Posted August 25, 2015 Share Posted August 25, 2015 Chris, when using a two post ramp where would you position the 4 pads? Quote Link to comment Share on other sites More sharing options...
Chris Wilson Posted August 25, 2015 Share Posted August 25, 2015 Assuming the car isn't a rot box, I would put the *RUBBER* pads under the sill points, but bear in mind the load is then spread evenly over the 4 points. Totally different to a trolley jack under just one of them.... My pet hate is crippled sill returns. Quote Link to comment Share on other sites More sharing options...
j_jza80 Posted August 25, 2015 Share Posted August 25, 2015 Just be careful which rubber pads you use. I used one of the generic ebay ones, which then split in 2, resulting in my sill return being crumpled Quote Link to comment Share on other sites More sharing options...
ripped_fear Posted August 25, 2015 Share Posted August 25, 2015 Just be careful which rubber pads you use. I used one of the generic ebay ones, which then split in 2, resulting in my sill return being crumpled At least Toyota didnt crumple yours, job on my list as my rears are bent. Need to go straighten them both. Quote Link to comment Share on other sites More sharing options...
Mk4Gaz Posted August 25, 2015 Share Posted August 25, 2015 Mine are all crumpled, from the previous owner. Really annoys me! I've straightened the rears back out, and have yet to do the fronts. I jack the front up with a low trolley jack, that just about slides between the wheel and wing, and lift off the front cross member. Having a trial rear, means I can't get to the diff when jacking up the rear, so I bought a hard rubber pad with a slot in it, specifically for sills. Quote Link to comment Share on other sites More sharing options...
GazDoran Posted August 25, 2015 Share Posted August 25, 2015 You guys are making me feel bad about my car! My sills are all crumpled - before I got the car - noticed the other day when I went to jack it up. Gonna have to straighten them out now! Quote Link to comment Share on other sites More sharing options...
JasonR24 Posted August 25, 2015 Share Posted August 25, 2015 This is a huge hate for me, getting mine sorted on the new car. It's only 2 of them but I like a perfect undercarriage would it be a body shop that would do them? Quote Link to comment Share on other sites More sharing options...
j_jza80 Posted August 25, 2015 Share Posted August 25, 2015 You guys are making me feel bad about my car! My sills are all crumpled - before I got the car - noticed the other day when I went to jack it up. Gonna have to straighten them out now! I don't envy you that task. The sill returns normally split when they are bent back. They will never be properly straight again. Quote Link to comment Share on other sites More sharing options...
Scott-tt Posted August 25, 2015 Share Posted August 25, 2015 Mine are crumpled too I drive up onto blocks of wood first this gives you easier access to the diff and front cross member with the trolley jack Quote Link to comment Share on other sites More sharing options...
kevin smith Posted August 26, 2015 Author Share Posted August 26, 2015 thank you everyone, what if I get a puncture and have to use the standard jack. I don't have a manual and with the skirts and it being lowered ?. Quote Link to comment Share on other sites More sharing options...
j_jza80 Posted August 26, 2015 Share Posted August 26, 2015 You should have thought about that before lowering your car! some scissor jacks go pretty low, might be worth having a look in your local breakers yard to see if there's any smaller ones. Quote Link to comment Share on other sites More sharing options...
Tyson Posted August 26, 2015 Share Posted August 26, 2015 thank you everyone, what if I get a puncture and have to use the standard jack. I don't have a manual and with the skirts and it being lowered ?. Looks like you're going to need to get recovered or get one of puncture repair can things Quote Link to comment Share on other sites More sharing options...
