grahamc Posted August 25, 2015 Share Posted August 25, 2015 Ok, shortly going to be setting up a new home office as I will be doing a fair bit of working from home and need some help on monitors. I will be running Surface Pro3 from a docking station, so I can add 2 other screens to it. So looking at monitors I would like to get 2x 24/27" monitors, but no idea what to go for? Any suggestions? I like the look of this:- http://www.ebay.co.uk/itm/Samsung-S27D590CS-27-Curved-LED-Monitor-Black-silver-1920-x-1080-New-/131494306398?hash=item1e9dabe25e I would also like to be able to hook my PS3 to the 2 screens, but that is a nice-to-have VS the screens for work. Link to comment Share on other sites More sharing options...
krisgowing Posted August 25, 2015 Share Posted August 25, 2015 Ok, shortly going to be setting up a new home office as I will be doing a fair bit of working from home and need some help on monitors. I will be running Surface Pro3 from a docking station, so I can add 2 other screens to it. So looking at monitors I would like to get 2x 24/27" monitors, but no idea what to go for? Any suggestions? I like the look of this:- http://www.ebay.co.uk/itm/Samsung-S27D590CS-27-Curved-LED-Monitor-Black-silver-1920-x-1080-New-/131494306398?hash=item1e9dabe25e I would also like to be able to hook my PS3 to the 2 screens, but that is a nice-to-have VS the screens for work. Are you all furnished out for you home office ? Link to comment Share on other sites More sharing options...
grahamc Posted August 25, 2015 Author Share Posted August 25, 2015 Not yet... Will also consider a single screen if that works the same just need to be able to divide it up Link to comment Share on other sites More sharing options...
Wez Posted August 25, 2015 Share Posted August 25, 2015 You could use a couple of these, connect the Surface with the DVI interfaces and run the PS3 into one with HDMI, also low response for gaming http://www.ebuyer.com/603605-iiyama-prolite-e2483hs-b1-24-hd-led-hdmi-monitor-e2483hs-b1 Not worth going 4k unless you spend a bit more, the cheaper 4k monitors are not worth, they are very very slow, the Dell ones even lag on fast mouse movement Link to comment Share on other sites More sharing options...
Wez Posted August 25, 2015 Share Posted August 25, 2015 Will also consider a single screen if that works the same just need to be able to divide it up For a single monitor solution these are nice, 34" Ultrawide takes some getting use to and they support side by side from multiple inputs, not cheap though :- http://www.ebuyer.com/642984-lg-34um95-p-34-led-ips-ultra-wide-qhd-monitor-34um95-p Link to comment Share on other sites More sharing options...
grahamc Posted August 25, 2015 Author Share Posted August 25, 2015 Thanks.... 250 per screen was the upper budget, so the ultra wide is touch expensive, but it does look good. Link to comment Share on other sites More sharing options...
Wez Posted August 25, 2015 Share Posted August 25, 2015 Thanks.... 250 per screen was the upper budget, so the ultra wide is touch expensive, but it does look good. Great for PC gaming, not sure how it would work on a PS3 tough as its a bit larger than 1080p res Cant go wrong with dual or triple 24" for most setups Although looks like 4k has moved on a bit, these look quite nice http://www.ebuyer.com/641287-samsung-u28d590-28-4k-60hz-led-monitor-lu28d590ds-en Link to comment Share on other sites More sharing options...
grahamc Posted August 25, 2015 Author Share Posted August 25, 2015 May have to make a switch to PC gaming.... Im really liking the idea of a single ultrawide screen now - all your fault! PS3 doesnt support ultrawide, but if its a very good screen, most seem to prefer it anyway, due to DPI and refresh rate. Hmmmm, decisions.......... Link to comment Share on other sites More sharing options...
