jsnlvxr Posted August 24, 2015 Share Posted August 24, 2015 Hi guys I've had a search but couldn't find any thing other than manual stuff. I'm basically swapping my na auto engine and box for a tt auto. However the prop out the gearbox is different.the tt box has 4 bolts to the prop but the na box has a splined male prop.what do I need to get this sorted. Would a tt auto prop bolt up to my current na auto diff? Thanks Quote Link to comment Share on other sites More sharing options...
dr_jekyll Posted August 24, 2015 Share Posted August 24, 2015 no Quote Link to comment Share on other sites More sharing options...
jsnlvxr Posted August 24, 2015 Author Share Posted August 24, 2015 So il need a rear diff too? Quote Link to comment Share on other sites More sharing options...
dr_jekyll Posted August 24, 2015 Share Posted August 24, 2015 no just the 3 bolt flange off an a02 or you could fit the a02 and have the longer ratio. Quote Link to comment Share on other sites More sharing options...
jsnlvxr Posted August 24, 2015 Author Share Posted August 24, 2015 Is the flange a weld on jib to the prop or easily changeable? Quote Link to comment Share on other sites More sharing options...
dr_jekyll Posted August 24, 2015 Share Posted August 24, 2015 its a 37mm bolt holding it on iirc. it unbolts from the diff then slides off a spline and will go straight on the a01. it has to be precisely tightened to 4 durka durkas of an impact wrench Quote Link to comment Share on other sites More sharing options...
jsnlvxr Posted August 24, 2015 Author Share Posted August 24, 2015 Lol ok that makes sense.thanks.just need to find the prop and flange then! Quote Link to comment Share on other sites More sharing options...
