Round 2, big single GTE.
FOSTA
  • Replies 389
So have the flappy paddles actually turned this into a tiptronic? How much of a job was it to fit?
Joe
Yeah it's full manual at a flick of a paddle now fella, it wasn't too bad to fit. As long as you can solder and fit a steering wheel your golden.
Obviously you need either a syvecs or suprastick to do it if you havnt got one already!
I've done a write up in the technical section on how to fit them :)
If you dont mind me asking what process did you go through to polish the covers? It would be a good project for these horrible weather days.
Basically you just need to sand them back to bear metal and get yourself a polishing mop that goes into a drill with some polishing compound and your set. Loads of videos on YouTube on how to do it. Very simple process but very time taking !!!
Sounds good, flappy paddles is probably what I'll go with later down the line. What gears does it allow you to select? From 1st to 4th or?
Yeah the full gear range down shift and up shift when ever you like so fully manual. 1st 2nd 3rd and 4th. :)
