Mk4Gaz Posted August 23, 2015 Share Posted August 23, 2015 Hi all, I'm looking to replace my trans fluid soon, and have been looking around for the correct type iv, without toyotas hugely inflated mark up! I've found this, and it seems very well priced, and it seems to be the correct stuff. Thoughts? : http://pages.ebay.com/link/?nav=item.view&id=360854355330&alt=web Quote Link to comment Share on other sites More sharing options...
Swampy442 Posted August 23, 2015 Share Posted August 23, 2015 Only later JZs ran type 4, if your box hasnt got type 4 on the sump plug/dip stick or isn't already running it its a needless expense. But go to GSF and look for ATF-U, its the same spec as Toyota type 4 but much cheaper. Quote Link to comment Share on other sites More sharing options...
Benjy Posted August 23, 2015 Share Posted August 23, 2015 I get quite a large discount at Toyota Gaz. Quote Link to comment Share on other sites More sharing options...
Mk4Gaz Posted August 23, 2015 Author Share Posted August 23, 2015 I just saw 10 litres for circa £40, and thought it was a great price! Quote Link to comment Share on other sites More sharing options...
peter richards Posted August 23, 2015 Share Posted August 23, 2015 how much does it take , looked at doing mine last year , didn't get round to it , but I read somewhere it wasn't a good idea to drain it all out , not sure why but just thought id mention it Quote Link to comment Share on other sites More sharing options...
Chris Bailey Posted August 23, 2015 Share Posted August 23, 2015 Think we just have a budget ATF in ours, but its due a change soon. Quote Link to comment Share on other sites More sharing options...
Dnk Posted August 23, 2015 Share Posted August 23, 2015 I never have understood the info with autobox fluid. Aren't a lot of boxes failing now due to the sealed for life misconception ? Quote Link to comment Share on other sites More sharing options...
peter richards Posted August 23, 2015 Share Posted August 23, 2015 ive had mine for around 15 years and ive not changed it so chances are its never been done , do I do it or not that's the question Quote Link to comment Share on other sites More sharing options...
Dnk Posted August 23, 2015 Share Posted August 23, 2015 ive had mine for around 15 years and ive not changed it so chances are its never been done , do I do it or not that's the question I drained mine out and it was long overdue in my opinion, no problems afterwards Quote Link to comment Share on other sites More sharing options...
peter richards Posted August 23, 2015 Share Posted August 23, 2015 ok , are there any filters needed dunk and what quantity Quote Link to comment Share on other sites More sharing options...
Dnk Posted August 23, 2015 Share Posted August 23, 2015 Theres a filter in the sump you change which I think David P knows where you can buy from much cheaper than Mr T Can't remember how much we got out of it now, it was a while ago Quote Link to comment Share on other sites More sharing options...
peter richards Posted August 23, 2015 Share Posted August 23, 2015 ok thanks Quote Link to comment Share on other sites More sharing options...
Dnk Posted August 23, 2015 Share Posted August 23, 2015 (edited) This is in the FAQ section Automatic 4-speed A340E Capacity = 8.2L's (But you can only really change what's in the sump of it and that is ~2L's) Stock = Toyota Type-IV - 2L's for a quick change. Have 10L's ready for a full flush. Recommended Oil = Toyota Type-IV / Fuchs Titan 4400 / Motul ATF 1A Interval = 1 years / 15,000 miles per 2L quick change with heavy use. 2 years and 30,000miles if you're a light user. NB: You only need to do a full flush if something is wrong....it could actually be harmful to do too many full flushes due to the additives in the oil. Edited August 23, 2015 by Dnk (see edit history) Quote Link to comment Share on other sites More sharing options...
David P Posted August 23, 2015 Share Posted August 23, 2015 Links to filters at best prices here. http://www.mkivsupra.net/vbb/group.php?discussionid=128&do=discuss I have the Group set to open access, yet for reasons unknown you may need to join the Group to access the page? Will send you a Group invite. Quote Link to comment Share on other sites More sharing options...
Mk4Gaz Posted August 23, 2015 Author Share Posted August 23, 2015 Links to filters at best prices here. http://www.mkivsupra.net/vbb/group.php?discussionid=128&do=discuss I have the Group set to open access, yet for reasons unknown you may need to join the Group to access the page? Will send you a Group invite. I'll be in touch very soon David, been meaning to call you for weeks now! Quote Link to comment Share on other sites More sharing options...
