The Raven Posted August 22, 2015 Share Posted August 22, 2015 Ok so had the ac charged on the Mrs 400h about 4 months back. Today it does not seem to be very cold so I'm guessing it's in need of a recharge again?!?,?. Is it possible to have a leak that takes so long to cause a problem? Quote Link to comment Share on other sites More sharing options...
peter richards Posted August 22, 2015 Share Posted August 22, 2015 sounds like, mine was good then had it gassed only for it not to be cold within a few weeks , turns out the condenser has a few leaks but just to expensive to be repaired . take it back they normally put a dye in the system that shows up any leaks under UV light , and the gassing machine normally stops if it detects a leak during the process , fingers crossed its an easy fix Quote Link to comment Share on other sites More sharing options...
MadMax2042 Posted August 22, 2015 Share Posted August 22, 2015 Sounds like the symptoms of a leak to me. If you got it re gassed at Lexus they should have put a dye in so it will highlight any leaks etc. Quote Link to comment Share on other sites More sharing options...
GreaseMonkey Posted August 22, 2015 Share Posted August 22, 2015 (edited) First thing to check is refrigerant amount in system (check in owners manual as can't remember at present), also make sure it has had either Denso ND11 A/C Compressor Oil or Hybrid Electric Vehicle A/C Compressor Oil Used, as these are not electrically conductive, whereas normal A/C compressor oil is and can damage the compressor/ short it out if put into the system. From my experience with A/C Leaks on the (MHU38) RX400h's the 3 main/ common points where they suffer from A/C leaks is The A/C Condenser Radiator (stone/ debris impacts) due to exposure/ little protection behind the bumper. Also there is a silver 10mm diameter A/C pipe (can't remeber if High or Low pressure A/C) located behind the front bumper metal crash bar ( when viewed from up underneath through bumper grille under Front No. Plate area. Leak visible on pipe area infront of A/C Condensor Radiator) that is prone for leaking due to debris impacts and poss cracking. This pipe runs along the front (as mentioned) and along passenger side of Engine bay over the Hybrid CVT transmission. Have known of another leak area on the above mentioned pipe (only noticeable with dye and UV lamp) from above the Hybrid CVT Transmission/ next to N/S Chassis leg visible through N/S/F Wheel arch. both leaks can be noticed from the oily and dirty residue on the pipes and condenser radiator. If the above mentioned pipe is leaking can be a 5hour labour approx job as N/S Headlamp, Front Bumper, N/S/F Engine bay Fuse Box, and Hybrid Inverter (not the gearbox but the unit mounted on top with the coolant bottle next to it ) require removal and refitting. I would only recommend a Reputable Lexus Dealer to carry the replacement of the mentioned pipe out, as not a job for an amateur mechanic due to involvement with the Hybrid electric system. Apologies for the long read, but all I can remember/ think of for now lol!, hth. Edited August 22, 2015 by GreaseMonkey (see edit history) Quote Link to comment Share on other sites More sharing options...
The Raven Posted August 23, 2015 Author Share Posted August 23, 2015 Thanks for the input guys. I think this is one for lexus. And hope its the rad. Quote Link to comment Share on other sites More sharing options...
Chris Wilson Posted August 24, 2015 Share Posted August 24, 2015 Pah, air conditioning indeed, remind her she lives in Kent, not Khartoum.... In a couple of months she'll be saying it's cold Quote Link to comment Share on other sites More sharing options...
