Guest suprageek Posted August 22, 2015 Share Posted August 22, 2015 (edited) So today i hadd to change my camshaft seals as they were leaking pretty badly, I took all the timing gear off and fitted the new seals, put it all back together as per the supra trsm, all the timing marks are lined up properly, when i start the car it sounds like it's not running on all cylinders and the check engine light is on, any ideas? It's a 93 tt auto thanks Edited August 22, 2015 by suprageek (see edit history) Quote Link to comment Share on other sites More sharing options...
Benjy Posted August 22, 2015 Share Posted August 22, 2015 Have you re-checked the timing? Quote Link to comment Share on other sites More sharing options...
Guest suprageek Posted August 22, 2015 Share Posted August 22, 2015 All the marks are lined up Ben, give it 2 rotations by hand before firing it up and they lined up perfect both times Quote Link to comment Share on other sites More sharing options...
Benjy Posted August 22, 2015 Share Posted August 22, 2015 What else did you remove that could affect the running? Quote Link to comment Share on other sites More sharing options...
Guest suprageek Posted August 22, 2015 Share Posted August 22, 2015 Had the coilpacks out, also the engine diagnosics was giving me code 22 the water temp sensor, the wire was broke and wouldn't start, I fixed it and it started but is running lumpy, sounds like a Subaru lol Quote Link to comment Share on other sites More sharing options...
Benjy Posted August 22, 2015 Share Posted August 22, 2015 Have you checked all the coil pack clips? And as stupid as it sounds, made sure you've plugged them in correctly? I'm pretty sure if the temp sensor was causing it not to start, and now it's repaired, it runs, that that won't affect it. Any codes now? Quote Link to comment Share on other sites More sharing options...
Guest suprageek Posted August 22, 2015 Share Posted August 22, 2015 I only removed the coilpacks, never unclilled the connectors. Still the same code mate 22, it's a bodge though atm will get the proper connector off Toyota next week. Quote Link to comment Share on other sites More sharing options...
Guest suprageek Posted August 23, 2015 Share Posted August 23, 2015 Update on this, now showing error code 14 unplugged the coilpack connectors one at a time and the engine stopped each time except when I pull the first connector the one closest to the cam gears Quote Link to comment Share on other sites More sharing options...
Benjy Posted August 23, 2015 Share Posted August 23, 2015 Check the wiring up to that connector mate. May have broken the 20 year old wire when you moved the coil packs out of the way. Another thing to try would be swapping 1&2 coil to 3&4 cylinders and see if the misfire moves. Quote Link to comment Share on other sites More sharing options...
Guest suprageek Posted August 23, 2015 Share Posted August 23, 2015 Sorted mate, there was a broken wire the the nearest coil, all good now Quote Link to comment Share on other sites More sharing options...
Benjy Posted August 23, 2015 Share Posted August 23, 2015 Quote Link to comment Share on other sites More sharing options...
