Emanage logs with first decat
Durandal
JDM supra with following mods:
- first cat removed
- 3" catback exhaust
- innovate wideband
- emanage-u (stock tune)
- blow off valve
- colder 8mm gapped plugs
Anyone see anything out of the ordinary with these logs? The second log was a pull in 5th gear when it cut out due to boost I believe since I do not have the boost cut activated yet. Plenty rich on WOT but that will change if boost cut is added.
Edited by Durandal (see edit history)
I don't know why they are running such high duty cycle, they are the 440c stock ones. Should they be upgraded to something a little bit bigger? The AFR is displayed on a gauge in my dash and is the green line on the log through option port 1 analog input. It's a innovate wideband 7.35-22.39 AFR range that I installed in my first decat pipe around where the cat temp sensor was.
I did take my foot of the throttle when I felt something cut out so maybe that's why it looks like that.
I got it because it was only a couple hundred more than buying Speed delimiter and BCC and gave me a platform for possibly going single in future. I also wanted to do some logging and figured there could be some benefit in some minor tuning with the lower octane available to me.
Oh ya totally understand. The AFR goes from around 13.5 to 15 while cruising and at WOT it drops down to 9.6 to 9.7 consistently. When I come off the throttle it spikes to maximum of 22 AFR which I do not understand, maybe that's normal or maybe it has to do with the BOV. I guess I kind of figured I could bring the AFR closer to 11.5 on WOT and do something about the dip around 4000 RPM with the injector map.
