rob.sherer Posted August 21, 2015 Share Posted August 21, 2015 Hey guys, I dont think my manu button is working. Or am i being a complete tool and need to follow some sort of process to get it to manual mode? Any help much appreciated Thanks Rob Link to comment Share on other sites More sharing options...
Jord Posted August 21, 2015 Share Posted August 21, 2015 Just pushing the manu button should activate it. If I remember right it has a light or says manu on the dash. You'll know it's in manu cus if you stick it in first you'll stay in first and it won't auto shift. Link to comment Share on other sites More sharing options...
Frank Bullitt Posted August 21, 2015 Share Posted August 21, 2015 If you click the blue hyper link manu it will like you to this page here - http://www.mkivsupra.net/vbb/showthread.php?86128-The-Autobox-Modes-of-Operation Link to comment Share on other sites More sharing options...
rob.sherer Posted August 21, 2015 Author Share Posted August 21, 2015 okay every time i have pressed it no light came on. anyone know what the issue could be? and thanks for the replies guys Link to comment Share on other sites More sharing options...
Jord Posted August 21, 2015 Share Posted August 21, 2015 Don't take my word for the light I'm sure there's some indication though but can't remember exactly. Is it staying in gear when you press it? Link to comment Share on other sites More sharing options...
rob.sherer Posted August 21, 2015 Author Share Posted August 21, 2015 no its not doesn't seem to do anything differently. taking car out for a drive tonight. will have a play around again then. never really used it but doing dyno session soon and need to to work ideally Link to comment Share on other sites More sharing options...
mattdavies Posted August 21, 2015 Share Posted August 21, 2015 Just have a look to check its all plugged in, its easy enough to have a look Link to comment Share on other sites More sharing options...
masterfett Posted August 21, 2015 Share Posted August 21, 2015 easy way to check have car in D at about 30 or whenever you car sits happily at about 1500 rpm.. press it and take the car up to about 2500rpm, let off the power if the revs drop its not working if they stay where they are as if in a manual car, its working. Link to comment Share on other sites More sharing options...
rob.sherer Posted August 21, 2015 Author Share Posted August 21, 2015 thanks masterfett will try that out tonight. And if that doesn't work will take it apart and check for any lose connections ect ect Link to comment Share on other sites More sharing options...
skippyboyo1 Posted August 21, 2015 Share Posted August 21, 2015 i think if you get the fault code it will say "replace with a manual" Link to comment Share on other sites More sharing options...
rob.sherer Posted August 21, 2015 Author Share Posted August 21, 2015 haha i want to belive me!! just founds are currently directed at aesthetics and ride quality now lol. some day tho!!! Link to comment Share on other sites More sharing options...
rob.sherer Posted August 24, 2015 Author Share Posted August 24, 2015 Tried what you all proposed and didn't work :'( won't be able to dyno now Link to comment Share on other sites More sharing options...
MadMax2042 Posted August 24, 2015 Share Posted August 24, 2015 You should be able to dyno just leave it in D and turn the overdrive off, that will keep you in 3rd gear Link to comment Share on other sites More sharing options...
rob.sherer Posted August 24, 2015 Author Share Posted August 24, 2015 Won't it step down to 2nd? Link to comment Share on other sites More sharing options...
thomo8568 Posted August 24, 2015 Share Posted August 24, 2015 (edited) From memory it connects to earth to work. So you could remove the switch and try bridging the wires or grounding the wire. Blue and white wires on the switch. Edited August 24, 2015 by thomo8568 (see edit history) Link to comment Share on other sites More sharing options...
secondjump Posted February 16, 2016 Share Posted February 16, 2016 Manu mode doesn't work because your trac ecu has been removed to permanently disable standard Toyota traction control. This is to prevent it interfering with Race Logic traction control but the down side is that Manu mode stops working too Link to comment Share on other sites More sharing options...
