Scott Posted February 12, 2016 Share Posted February 12, 2016 Ah ok thanks Scott how would they be adjusted? Via syvecs? I'm not sure if there is any adjustment in it to be honest, I'm struggling to remember how it works I know you can adjust the throttle position sensor (I doubt it would be that but for the sake of a check that would be worth it too). The Toyota manual gives resistance values for the TPS sensor for definite. Quote Link to comment Share on other sites More sharing options...
a98pmalcolm Posted February 12, 2016 Author Share Posted February 12, 2016 I thought the oem battey possative went the the starter and then a cable from starter to altinator? Yer theres fuse to the sub amp and its half way down the line.. Quote Link to comment Share on other sites More sharing options...
a98pmalcolm Posted June 17, 2016 Author Share Posted June 17, 2016 Quick bump on this, After Romain recently logged onto my ECU I'm actually getting a drop to 9 volts, being the reason its not starting great. Any other ideas? Quote Link to comment Share on other sites More sharing options...
supra matt Posted June 17, 2016 Share Posted June 17, 2016 The start motor cable connection goes straight to the battery no where eles sounds like a bad ground or cable to starter motor not man enough. Have you still got the ground on the engine to the chassis leg? Quote Link to comment Share on other sites More sharing options...
chazuk Posted June 17, 2016 Share Posted June 17, 2016 (edited) I had some strange problems the first time I did my battery to boot I bought some 0 gauge from eBay. I then bought 0 gauge which was almost triple the cost it was also about double the weight ! I got it from a marine place replaced the main run to the boot and the earth instantly sorted it . Looking at your pictures the terminals look on the small side bit like my first cable the 2nd one I had to get my mate with his bolt cropper size crimps to do the ends Edited June 17, 2016 by chazuk (see edit history) Quote Link to comment Share on other sites More sharing options...
supra matt Posted June 17, 2016 Share Posted June 17, 2016 Yes you need 100% copper cable to none of this cheap tined stuff as it doesn't have the current carrying capacity of the real deal Quote Link to comment Share on other sites More sharing options...
a98pmalcolm Posted June 18, 2016 Author Share Posted June 18, 2016 After reading on the net ideally going 200 amps+ to support cold start so I came accross this stuff http://www.ebay.co.uk/itm/321991756343?_trksid=p2060353.m1438.l2649&var=510923333815&ssPageName=STRK%3AMEBIDX%3AIT Quote Link to comment Share on other sites More sharing options...
a98pmalcolm Posted June 26, 2016 Author Share Posted June 26, 2016 Solved, 1st post emended Quote Link to comment Share on other sites More sharing options...
