'91 Soarer sub frame on '94 supra?
Bizzyfingers
Part numbers are different but it has been done the other way around so should fit more or less OK (there may be a minor issue with the ARB as (AFAIK) the Soarer mountings are on the body not on the sub-frame like the Supra. However the reason for doing it the other way around (MKIV sub-frame to Soarer) is to improve the handling. Apparently the Supra control arms are shorter which (it has been said) increases rear end stiffness.
I've got the soarer as a donor car and loads of parts on it the rear subframe looks in much better condition than mine. Just wanting to salvage as many bit's. Heard they are interchangeable and you guys are the best to ask.
If you're salvaging bits from a Soarer don't forget the integration relay and Fuel Pump ECU. They're both getting pretty rare in working order.
