j_jza80 Posted August 18, 2015 Share Posted August 18, 2015 Having bought a TRD LSD for my car, I have also obtained both a manual and an auto small case differential, so I have the choice of building it into either. Now, I know that several forum members have used auto diffs in their manual cars in order to make them accelerate more quickly, but has anyone used a manual diff in an auto? I realize that it will have a negative effect on acceleration, but as this will be part of a single turbo conversion with a hopeful 550hp, will the effects be noticeable? The reasons I am considering it is because at some point I would quite like to take my car above 200mph (who doesn't? ), and improved cruise fuel economy. As my car is a daily, it would be a bonus. Attached below are screengrabs of the forum 'wheel size and gearing calculator' (thanks Homer! ), the first showing stock tiptonic gearing with my wheels, the second showing the tiptronic/auto gearbox with a small case 6 speed diff. Quote Link to comment Share on other sites More sharing options...
Scott Posted August 18, 2015 Share Posted August 18, 2015 Are the casings actually different? I thought the ratio came from the diff itself, so you would need to check the ratio of the TRD variant. Unless I'm missing something? Quote Link to comment Share on other sites More sharing options...
j_jza80 Posted August 18, 2015 Author Share Posted August 18, 2015 (edited) No, the casings are the same as is the diff. The terminology is a bit beyond me, but IIRC it is the pinion gear on the diff input shaft that determines the ratio. Hopefully someone informed will be along shortly! Edited August 18, 2015 by j_jza80 (see edit history) Quote Link to comment Share on other sites More sharing options...
