Intercooler pipe Joiners Silicone vs Rubber
mattdavies
The silicone may have a higher burst pressure, but as I have never seen a stock pipe or pipe joiner burst it is irrelevant. the silicone pipes vary from excellent to utter junk, like most aftermarket stuff. OE rubber is less likely to blow off as silicone is much more slippery.
As an aside people who fit "hard pipe" kits thinking they improve spool need to read their physics books, they make no difference whatsoever, and are purely a wallet opening exercise.
I fitted a hardpipe kit as:
1) Was fitting a new SMIC, so it was pretty straight forward to do
2) figured that replacing the stock basic jubilee clips with constant tension clamps was probably a good idea for raised boost pressures.
3) the stock intercooler hose that sits behind the airbox, and the one that connects to the throttle both deteriorate badly with age and heat, and Iv'e seen several that contact badly.
