james_cbr Posted August 10, 2015 Share Posted August 10, 2015 Read through the engine and coolant system pdf but cant fined the torque to tighten the 2 half's of the water pump Link to comment Share on other sites More sharing options...
adam1983 Posted August 11, 2015 Share Posted August 11, 2015 Is this what you are looking for? It has all the torque settings for each step. Link to comment Share on other sites More sharing options...
adam1983 Posted August 11, 2015 Share Posted August 11, 2015 Or maybe this but you are talking about? Link to comment Share on other sites More sharing options...
james_cbr Posted August 11, 2015 Author Share Posted August 11, 2015 Those are the ones I have I'm after the small bolts that hold the front and rear halfs of the pump together Link to comment Share on other sites More sharing options...
Chris Wilson Posted August 11, 2015 Share Posted August 11, 2015 Just do them by feel, they should not be over done, they are both into relatively soft alloy. Link to comment Share on other sites More sharing options...
james_cbr Posted August 11, 2015 Author Share Posted August 11, 2015 Yeh would you say safe to do 21 nm same as the main bolts holding it on or more like a 12-14 nm I'm trying to do it all by the book Link to comment Share on other sites More sharing options...
Chris Wilson Posted August 11, 2015 Share Posted August 11, 2015 I would never use a torque wrench on them, I would do it by feel. But bear in mind the bolts that go THROUGH both castings go into the cast iron block. The 2 bolts you mention go into soft alloy, so I would be much gentler with those. Maybe 12 / 13 nm (around 10 lbs ft). Link to comment Share on other sites More sharing options...
