*UK Spec 6 speed Single Turbo built engine*
Lee P
Advertising this car on behalf of a customer, we fitted the Syvecs ecu and had Ryan map it
Its great spec and condition car for the money.
Some info from the owner
1995 Toyota Supra UK 6 Speed - Single turbo conversion
I have owned this car since October 2000, I’m the 3rd owner and with a current mileage just short of 90,000 miles. MOT is current and can brought up to date for the sale.
General condition
Overall the car is in very good condition inside and out, I’m not aware of any rust and only a few minor scratches and stone chips on the bodywork.
The electric Aerial is broken but have an S2000 one to replace it
The car was serviced 3 years ago and has been MOT’d every year but hasn’t been driven.
Engine
This engine was built and used by JPS Motorsport in the early days of his orange drag car and has run at 850+ HP at Santa Pod. The engine was specifically built for high HP and high temps, balanced; compression is in spec and almost identical across all cylinders.
The car was tuned by Ryan of 2bar Tuning at Surrey Rolling Road 560HP@ 1.6 bar
HKS (Carrillo) rods
Oversize CP Piston and Ring Set (3.1 litres)
New crank
HKS 256 Inlet cam
HKS 264 outlet cam
Ferrea Ti retainers
Polished Q45 throttle body, manifold and cam covers.
Up rated crank damper & alloy pulleys
Kevlar cam belt
Powerhouse racing 72mm dual ball bearing Turbo
HKS ceramic coated manifold
PHR 4” ceramic coated downpipe/midpipe
850CC Fuel injectors
Twin Walbro pumps & lines
Veilside Titanium exhaust (with optional bung)
Dual HKS BOV’s
Aeromotive Fuel Pressure Regulator
Carbon fibre coated spark plug cover
Cooling
GReddy Intercooler with hardpipes
10 row power steering cooler
16 row Oil Cooler
Rear diff cooler has been replaced.
Custom Airbox
PWR Polished Aluminium Radiator with twin electric fans (ECU Controlled)
Aluminium Rad overflow tank
Top radiator hard pipe (chromed)
Electronics
Innovate Motorsports Wideband (ECU Connected)
Syvecs S6 ECU – Tuned by Ryan@2BAR
Coil packs replaced with ECU
Enhanced Knock sensors (ECU monitored)
Oil pressure probe (ECU monitored)
EGR probe (ECU monitored)
Boost control valve (ECU controlled and monitored)
Laser Line Cat 1 Thatcham approved Car alarm
Transmission
AP Engineering Shifter Bushing Kit for Manual Transmission
Modified clutch slave cylinder & braided line
Six puck metallic clutch
Toyota flywheel replaced less than 1000 miles ago
Suspension
TEIN HA coil overs (with EDFC not fitted)
TRD Anti-roll bars
Interior
TRD 10K teach
Toyota Celica steering wheel and ABS connector
MVP Aluminium pedal covers
MVP Aluminium dial surround
Sparco Milano Prestige leather seats (£800+ each)
Bride seat rails
Leather gear and handbrake covers.
Double DIN DVD and MP3 head unit (£400)
Kenwood amp & lightweight speakers
Other
Upgraded steering rack bushes
UK Spec brakes with full braided stainless, coated hoses
Aluminium Under tray and cooling plate
Whifbitz lower lip with 2” hose pickups
18” CCW Classic Wheels & tyres – 1000 miles (£2500+ new)
C16 SUP number plate
Price is £16,995
Car is located in Crawley West Sussex
  • Replies 75
  • 2 weeks later...
Hello am interested in buying your supra is there any room for negotiation on the price would like to come get it this weekend thanks
Unfortunately not.
The price is already very good for this car being a Uk 6 speed with this spec.
