Lee P Posted August 24, 2015 Share Posted August 24, 2015 What do you mean a lock up switch? So you can lock the TC while cruising to drop the rpm down Quote Link to comment Share on other sites More sharing options...
T14PPA Posted August 24, 2015 Share Posted August 24, 2015 Oww ok would i need one Quote Link to comment Share on other sites More sharing options...
David P Posted August 24, 2015 Share Posted August 24, 2015 (edited) Take a look at the video about hi stall torque converters that I've just posted in the transmission group, it explains that your t.c. will be slipping up to around 3,600 rpm which means that it will be slipping almost all of the time with road driving and will generate lots of heat. Several U.K. Engine Tuners claim that with an AEM ECU, the torque converter never completely locks up and they like to fit a lock up switch to use for motorway driving and dyno runs. http://www.mkivsupra.net/vbb/group.php?discussionid=182&do=discuss Edited August 24, 2015 by David P (see edit history) Quote Link to comment Share on other sites More sharing options...
TT Paul Posted August 24, 2015 Author Share Posted August 24, 2015 would you use the lock up switch for say around town or just m/way ?? pulling away ?? just want to make sure i use switch in the right place Quote Link to comment Share on other sites More sharing options...
David P Posted August 24, 2015 Share Posted August 24, 2015 How many times do I need to write; "a lock up switch to use for motorway driving and dyno runs" only. If you have stock cams, the best torque-converter is the stock torque-converter. If it's a road car, the best torque converter is a stock torque-converter. Quote Link to comment Share on other sites More sharing options...
Slam Posted August 24, 2015 Share Posted August 24, 2015 Sorry that didn't sink in, can you repeat that Quote Link to comment Share on other sites More sharing options...
Chris Bailey Posted August 24, 2015 Share Posted August 24, 2015 We have a 3600 torque converter, and are changing back to stock torque converter. Just for a more smoother power delivery. Quote Link to comment Share on other sites More sharing options...
TT Paul Posted August 25, 2015 Author Share Posted August 25, 2015 How many times do I need to write; "a lock up switch to use for motorway driving and dyno runs" only. If you have stock cams, the best torque-converter is the stock torque-converter. If it's a road car, the best torque converter is a stock torque-converter. Sorry couldnt see the group Quote Link to comment Share on other sites More sharing options...
