Silicone For IC/Throttle Body
terribleturner
Thought i had a boost leak last night and hey presto i just go check and the silicone pipe off the throttle body onto an IC pipe has a massive great split in it. The size is 70-80mm (small to big), anyone know where i can get a replacment piece from or anyone have one lying around. May see if the original piece can go on for now.
I looked on your website Paul and couldn't see anything listed :( knew i should have called.
Just type in silicon in the search
http://miami-gt.com/advanced_search_result.php?osCsid=70ccc69a5cb13d0b7842b150724d3aeb&keywords=silicon&osCsid=70ccc69a5cb13d0b7842b150724d3aeb
Anyway - cany specify everything that is knocking around - so no worries
let me know if you are stuck OK?
