lewis hill Posted August 8, 2015 Share Posted August 8, 2015 (edited) Hi lads as some may know I want to go single. Im looking for a used hks f con v gold or piggy back. I don't know much about ecu's but the harnesses are what determine the car it's used for I guess? I've seen a hks fcon gold v for sale on its own for £450. Is this a decent price? If I bought it would I just buy a harness to get it to work on the supra? is there any other sensors that would be advisable Cheers Edited August 8, 2015 by lewis hill (see edit history) Quote Link to comment Share on other sites More sharing options...
Nic Posted August 8, 2015 Share Posted August 8, 2015 Minimum you'll want is: HKS F-Con V Pro HKS F-Con V Pro Harness HKS F-Con Pressure Sensor HKS F-Con Temp Sensor The F-Con can only be mapped by an HKS Pro dealer and some of the older models are not compatible with the latest software, so before buying I would investigate who can map it for you, how much the mapping will cost and whether the model of ECU you are buying can be mapped. Quote Link to comment Share on other sites More sharing options...
chazuk Posted August 8, 2015 Share Posted August 8, 2015 far better off with a power fc just about every tuner can map one , ryan did mine it was a great standalone plug and play ecu for very little money Quote Link to comment Share on other sites More sharing options...
lewis hill Posted August 8, 2015 Author Share Posted August 8, 2015 Minimum you'll want is: HKS F-Con V Pro HKS F-Con V Pro Harness HKS F-Con Pressure Sensor HKS F-Con Temp Sensor The F-Con can only be mapped by an HKS Pro dealer and some of the older models are not compatible with the latest software, so before buying I would investigate who can map it for you, how much the mapping will cost and whether the model of ECU you are buying can be mapped. Okay thanks. I've spoken to mark at tdi and he maps hks fcon and isn't far from me. It was a 3.1 so I think I read it should be fine? Quote Link to comment Share on other sites More sharing options...
lewis hill Posted August 8, 2015 Author Share Posted August 8, 2015 far better off with a power fc just about every tuner can map one , ryan did mine it was a great standalone plug and play ecu for very little money Oh really? I was recommended a hks fcon by srd using torque developments to map. Who could map an power FC other than Ryan? As he is moving to dubai soon he said Quote Link to comment Share on other sites More sharing options...
