Hks F-con
lewis hill
Hi lads as some may know I want to go single. Im looking for a used hks f con v gold or piggy back. I don't know much about ecu's but the harnesses are what determine the car it's used for I guess?
I've seen a hks fcon gold v for sale on its own for £450. Is this a decent price?
If I bought it would I just buy a harness to get it to work on the supra?
is there any other sensors that would be advisable
Cheers :)
Edited by lewis hill (see edit history)
Minimum you'll want is:
HKS F-Con V Pro
HKS F-Con V Pro Harness
HKS F-Con Pressure Sensor
HKS F-Con Temp Sensor
The F-Con can only be mapped by an HKS Pro dealer and some of the older models are not compatible with the latest software, so before buying I would investigate who can map it for you, how much the mapping will cost and whether the model of ECU you are buying can be mapped.
HKS F-Con V Pro
Okay thanks. I've spoken to mark at tdi and he maps hks fcon and isn't far from me. It was a 3.1 so I think I read it should be fine?
far better off with a power fc just about every tuner can map one , ryan did mine it was a great standalone plug and play ecu for very little money
Oh really? I was recommended a hks fcon by srd using torque developments to map. Who could map an power FC other than Ryan? As he is moving to dubai soon he said :(
