mrboost Posted September 7, 2005 Share Posted September 7, 2005 OKAY DOKEY Any Ideas how you can get the crank nut off ? ITS BLOOMING TIGHT!!! Wanted to change cam and fit my new camshafts and cam gears Link to comment Share on other sites More sharing options...
bignum Posted September 7, 2005 Share Posted September 7, 2005 right u need a 3 quarter" drive socket and bar wedge it under THE DRIVERS SIDE CHASSIY [right hand drive of course] in nuetral turn the key undoes the bolt,,,watched a guy do it with mine,risky but did the trick ps dont use heat on it the front seal is liable to blow afterwards good luck. Link to comment Share on other sites More sharing options...
merckx Posted September 7, 2005 Share Posted September 7, 2005 http://www.max-boost.co.uk/max-boost/resources/SUPRA_MKIV/Timing_Belt_Removal.pdf Use a long breaker bar to get more leverage or Like bignum said, some have used the starter motor to turn over the engine and therefore rotating the crankshaft to loosen the bolt. The wrench will have to be fixed so it won't rotate, only worth doing it this way if you're confident that you won't break anything. You don't want to start the engine so you'll have to prevent this by disconnecting the ignition pack or removing a fuse. Link to comment Share on other sites More sharing options...
paul mac Posted September 7, 2005 Share Posted September 7, 2005 there was a guy on the board who did a rental on the gear you need, dont know if he's still about, do a search Link to comment Share on other sites More sharing options...
eyefi Posted September 8, 2005 Share Posted September 8, 2005 a 6ft bar did it on mine, in gear with the hand brake on, wheels on the floor. do you have to take the crank pulley off to do the cams and gears, can't you just remove the belt tensioner? Link to comment Share on other sites More sharing options...
bedlam Posted September 8, 2005 Share Posted September 8, 2005 Read this thread... http://www.mkivsupra.net/vbb/showthread.php?t=45538 Go to the link i posted, and make yourself one of the tools Jake has posted pics off. Andy Link to comment Share on other sites More sharing options...
neo1 Posted September 8, 2005 Share Posted September 8, 2005 The bolt is a sod, i used the starter motor trick in the end and then the pulley tool to torque the new bolt back up. Link to comment Share on other sites More sharing options...
DShox Posted September 9, 2005 Share Posted September 9, 2005 by the way - anyone know how much it costs to do cambelt and how often should these by changed on a TT? ta, D. Link to comment Share on other sites More sharing options...
mrboost Posted September 12, 2005 Author Share Posted September 12, 2005 well huge thank you again. I had been told that the engine would have to come out as the crank bolt was too tight, tried it myself and heh it came off no problem....Did a few extra things like cam gears camshaft etc...But all in all less than 4 hours all done (with help from a close friend who is a mechanic). Winner thanks guys & girls http://www.shef.ac.uk/misc/personal/mdb/test/pic1.jpghttp://www.shef.ac.uk/misc/personal/mdb/test/pic4.jpghttp://www.shef.ac.uk/misc/personal/mdb/test/pic10.jpg http://www.shef.ac.uk/misc/personal/mdb/test/pic25.jpghttp://www.shef.ac.uk/misc/personal/mdb/test/pic16.jpg Link to comment Share on other sites More sharing options...
bedlam Posted September 12, 2005 Share Posted September 12, 2005 Engine out LMAO well thats a new one . And looking nice mate . Andy Link to comment Share on other sites More sharing options...
Ian C Posted September 12, 2005 Share Posted September 12, 2005 Aiiieeeee HKS cam gears, and exposed at that! That engine may be coming out soon anyway -Ian Link to comment Share on other sites More sharing options...
mrboost Posted September 12, 2005 Author Share Posted September 12, 2005 Did not no that !! But mine are the new type...As I asked why mine were not blue and purple but chrome/silver & purple. So I'm the Ginea Pig at the moment ? Link to comment Share on other sites More sharing options...
Ian C Posted September 12, 2005 Share Posted September 12, 2005 Yup -Ian Link to comment Share on other sites More sharing options...
