Guest vegax22 Posted August 6, 2015 Share Posted August 6, 2015 I have read some of the post on the diffrences between the two engine and what i have gathered is that beside the low compresion piston n head and oil squirter the two engine are the same able to produce the same mass power if build properly. Can anyone confirm this. I have an NA and i was planning on going with the crower 3.4 L strocker kit then rebuild my head port polish value and spring as well as cams. Then putting TT on it . Would i be able to get the same result as if i build a gte the same way. Link to comment Share on other sites More sharing options...
Gaz6002 Posted August 6, 2015 Share Posted August 6, 2015 School holidays, eh? Link to comment Share on other sites More sharing options...
Guest vegax22 Posted August 6, 2015 Share Posted August 6, 2015 Thanks for the input helped tones Link to comment Share on other sites More sharing options...
Gaz6002 Posted August 6, 2015 Share Posted August 6, 2015 Well to be fair, your question isn't exactly helpful either. So you're going to rebuild your NA head, then "putting a TT on it" would do what? Do you mean big twin turbos, the stock twins, an Audi? Link to comment Share on other sites More sharing options...
Guest vegax22 Posted August 6, 2015 Share Posted August 6, 2015 It would be big twin turbo what i want to know is should i find a 2jzgte n build that or can i get the same results if i build my 2jzge since it is the same block? Link to comment Share on other sites More sharing options...
Style Posted August 6, 2015 Share Posted August 6, 2015 Compression ratios are different for a start so pistons will have to be changed for any power levels over 400hp or so on a stock NA engine. TT pistons will allow you to push some more power out of the NA. You'll also find a lot more parts for GTE engines as the manifold patterns are both different. Same applies to ECU's. There's a lot more readily available Link to comment Share on other sites More sharing options...
