Guest she1by1 Posted August 3, 2015 Share Posted August 3, 2015 Hello, this is my first thread with a cry for help so please bear with me  The revs in my supra started to drop and fluctuate whilst maintaining a constant speed, video here  The car then stalled at a junction but I managed to get her started and limp her home. When I have turned the car on again to try and diagnose the problem, big clouds of black smoke come out of the exhaust. I have been looking through a few threads and thought it may have been the Idle control valve. However, this has been cleaned, put back on, still not worked, new one put on, still not worked. Myself and my boyfriend are completely lost on what the problem could be, and the car has now been off the road for 2 weeks now. Any help/ideas would be much appreciated x Quote Link to comment Share on other sites More sharing options...
David P Posted August 3, 2015 Share Posted August 3, 2015 Is it T.T. or N/A? Quote Link to comment Share on other sites More sharing options...
Guest she1by1 Posted August 3, 2015 Share Posted August 3, 2015 Sorry forgot to mention it's a N/A Quote Link to comment Share on other sites More sharing options...
David P Posted August 3, 2015 Share Posted August 3, 2015 The jittery rev counter could signify a dicky crank position sensor. Try swapping in another distributor, another thing to check would be the igniter earth. Quote Link to comment Share on other sites More sharing options...
Style Posted August 3, 2015 Share Posted August 3, 2015 I just had a similar problem. Turns out it was the distributor leads to cylinders 5 and 6. They were knackered and were arcing out on the block before reaching the cylinder and igniting the petrol/air mixture. Black smoke everywhere as unburnt petrol was just pissing through the block. Luckily got it sorted before any major damage was done to the cylinders. So another vote for David P's method to fix, replace your distributor and leads. That should hopefully fix the problem Quote Link to comment Share on other sites More sharing options...
wile e coyote Posted August 3, 2015 Share Posted August 3, 2015 yep as above when were all the plugs changed as people don't bother with 4 and 5 due to having to remove the throttle boddy Quote Link to comment Share on other sites More sharing options...
Guest she1by1 Posted August 3, 2015 Share Posted August 3, 2015 All 6 were changed in the summer last year, manifold and throttle body all off thanks for your help so far guys, new leads, dizzy cap and rotor arm are now on order. Will see if that works then will try the crank sensor, can't seem to find anywhere to get hold of one apart from Australia?!?! Quote Link to comment Share on other sites More sharing options...
David P Posted August 3, 2015 Share Posted August 3, 2015 Check that the igniter is secured, the earth is through the fixings. The crank sensor is in the distributor and it's simple enough to swap in a second hand distributor to find out. Quote Link to comment Share on other sites More sharing options...
Nic Posted August 3, 2015 Share Posted August 3, 2015 All 6 were changed in the summer last year, manifold and throttle body all off thanks for your help so far guys, new leads, dizzy cap and rotor arm are now on order. Did you fit genuine Toyota parts? Quote Link to comment Share on other sites More sharing options...
Guest she1by1 Posted August 3, 2015 Share Posted August 3, 2015 My engine is completely standard, denso iridium plugs fitted last year Quote Link to comment Share on other sites More sharing options...
