Buckled power steering pump/pulley
berg
I noticed my power steering pulley turns like a badly buckled wheel
I thought it maybe the pulley but its doing the same thing with the polished pulley Ive fitted
Is this likely to be a knackered pump in some way?
Will it be repairable or will i need to replace it?
The front bearing may be absolutely shot, but if it's as bad as you say there may be rotor and rotor housing damage. I usually charge circa £130 to re-build PAS pumps, but would need to open it up and assess internal condition for a firm quote. If you leave it it will be creating debris and knackering up the rack as well.
  • 2 weeks later...
Took a quick vid just to show how bad it actually is
give up trying to embed the video i cant do it lol
Edited by berg (see edit history)
