jza800 Posted July 27, 2015 Share Posted July 27, 2015 I have a serpentine belt that squeal, i have all the stock damper on the crankshaft and whifbitz wheels on the alternator - power sterring pump - water pump - drive belt tensioner pully, and new gates serpentine belt on.. the belt does not go from side to side on the wheels, so with this in mind and when i put soap water on the squeal dissapers for a short while, then come back, so that in mind, i now i dont have a bearings fault on the engine, but a belt or alignment problem on the wheels... someone have had same problems???? Link to comment Share on other sites More sharing options...
Chris Wilson Posted July 28, 2015 Share Posted July 28, 2015 Some makes of belt make a noise on some pulleys. Gates are usually OK, but once you start fitting alloy pulleys then they may be noisy. Try other makes of belts or turn the wireless up. Link to comment Share on other sites More sharing options...
