Dutchman Posted July 27, 2015 Share Posted July 27, 2015 Hi guys, ive not had my TT6 long but have decided for peace of mind I'm going to fully service it, i have documentation of it being serviced 4K ago but i will do it just so I know it's been done right What oils/filters/plugs etc Would you guys recommend? Quote Link to comment Share on other sites More sharing options...
spikedjack Posted July 27, 2015 Share Posted July 27, 2015 Engine oil, filter, plugs, air filter, fuel filter, gearbox and diff oils should see you right. Probably need coilpack clips too while you're on. Also , check the crank pulley, coolant, brake fluid and the length of time since the last cambelt change Quote Link to comment Share on other sites More sharing options...
spikedjack Posted July 27, 2015 Share Posted July 27, 2015 Also, the oils thread in the help zone lists all the correct ones to use Quote Link to comment Share on other sites More sharing options...
Nic Posted July 27, 2015 Share Posted July 27, 2015 http://www.mkivsupra.net/vbb/showthread.php?56684-FAQ-Oil-Fluid-Interval-Capacity-Steering-Brake-Coolant-Diff-Engine http://www.mkivsupra.net/vbb/showthread.php?41927-FAQ-Spark-plugs Quote Link to comment Share on other sites More sharing options...
Dutchman Posted July 27, 2015 Author Share Posted July 27, 2015 Thanks for the replies guys I'll get ordering stuff right away, the coil pack clips were changed right before I bought it the crank pulley was also changed (less than 2k ago) I'll have a ratch through all the history to see about the cambelt Quote Link to comment Share on other sites More sharing options...
