David P Posted July 29, 2015 Share Posted July 29, 2015 (edited) Maybe double whammy would be a better option? I'll just remove that for decency as this is Tech, not off-topic NWS... -Ian Edited July 29, 2015 by Ian C (see edit history) Link to comment Share on other sites More sharing options...
Dim Sum Posted July 29, 2015 Share Posted July 29, 2015 Maybe double whammy would be a better option? https://40.media.tumblr.com/tumblr_m9t0vmJB8W1r99e9eo1_500.jpg lol. I have a spare ECU you can borrow and check Listy, if you are interested let me know and I send in through the post. Link to comment Share on other sites More sharing options...
nihontoman Posted July 29, 2015 Share Posted July 29, 2015 yeaah, maybe I should reconsider... :| Link to comment Share on other sites More sharing options...
listy Posted July 29, 2015 Author Share Posted July 29, 2015 Is it ok to gamble here? if it is, I'd bet my left nipple that it's just the battery that's gone dead... take out a battery and take it to the nearest shop. they should be able to easily check if it's healthy... Battery is fine. It starts, just dies. Plus I tried a spare charged battery before I got it recovered to no avail. So, where and when can I collect this left nipple - - - Updated - - - Wrong that Ian, he's pushed the red button It's a manual....I have no red button Link to comment Share on other sites More sharing options...
stevie_b Posted July 29, 2015 Share Posted July 29, 2015 Is it ok to gamble here? if it is, I'd bet my left nipple that it's just the battery that's gone dead... take out a battery and take it to the nearest shop. they should be able to easily check if it's healthy sell you a new one regardless of the state of the old one Corrected Link to comment Share on other sites More sharing options...
nihontoman Posted July 29, 2015 Share Posted July 29, 2015 Battery is fine. It starts, just dies. Plus I tried a spare charged battery before I got it recovered to no avail. So, where and when can I collect this left nipple Ok, I'll bequest it to you or your descendants after I'll die Corrected yeaah, that's sounds just about right... Link to comment Share on other sites More sharing options...
Swampy442 Posted July 29, 2015 Share Posted July 29, 2015 Fuel pump ECU. Bridge the ports B+ and Fp in the diagnostic port, see if it fires up/ Link to comment Share on other sites More sharing options...
listy Posted August 9, 2015 Author Share Posted August 9, 2015 Well, today is finally the day to investigate. Can someone remind me which ports to bridge to pull error codes please. Link to comment Share on other sites More sharing options...
Josh42 Posted August 9, 2015 Share Posted August 9, 2015 Well, today is finally the day to investigate. Can someone remind me which ports to bridge to pull error codes please. E1 and TE1 are the diagnostics ports mate Link to comment Share on other sites More sharing options...
listy Posted August 9, 2015 Author Share Posted August 9, 2015 Cheers Josh. Hoping something simple is the cause. Fingers crossed. Link to comment Share on other sites More sharing options...
listy Posted August 9, 2015 Author Share Posted August 9, 2015 Right. Discovered over the two weeks the Supra has been sat that the battery has died. Bridged E1 and TE1 and comes up no stored codes. I'm guessing this is because the ECU has reset itself since the battery died. Any ideas where to go from here? Link to comment Share on other sites More sharing options...
David P Posted August 9, 2015 Share Posted August 9, 2015 Charge the battery. Link to comment Share on other sites More sharing options...
listy Posted August 9, 2015 Author Share Posted August 9, 2015 I'm not that silly David I put another battery in and pulled the (lack of) error codes. I can't run it to process error codes as it doesn't run. At a bit of crossroads right now. I have had a thought though.... VSS need doing, is it possible that oil has pooled in the spark plug wells and is stopping a spark? Therefore no ignition. I think removing the plugs and giving it all a good clean out will be my first port of call. List of possibilities I have: Map sensor hose Ignition related (injectors?/plugs?/coil pack clips?/coil packs?) Fuelling (pump?/blocked lines?/filter?) ECU Any other ideas? It won't even rough idle now. The engine tries, shakes a bit and dies. Link to comment Share on other sites More sharing options...
David P Posted August 9, 2015 Share Posted August 9, 2015 (edited) It would have been easier to look at the MAP sensor hose than to post that you haven't. Edited August 9, 2015 by David P (see edit history) Link to comment Share on other sites More sharing options...
Josh42 Posted August 9, 2015 Share Posted August 9, 2015 It would have been easier to look at the MAP sensor hose than to post that you haven't. This, check the map sensor, faulty earths and obvious things first mate Link to comment Share on other sites More sharing options...
listy Posted August 9, 2015 Author Share Posted August 9, 2015 I'll check the map sensor later after the football Link to comment Share on other sites More sharing options...
listy Posted August 9, 2015 Author Share Posted August 9, 2015 MAP sensor looks fine. All hoses etc where they should be. That can be crossed off the list. Link to comment Share on other sites More sharing options...
Chris Wilson Posted August 9, 2015 Share Posted August 9, 2015 If it's got an FCD remove or bypass it. Forget oil or oil in the plug wells, won't be that. Check hoses / T's to the MAP sensor. Fit new plugs and try again. Link to comment Share on other sites More sharing options...
David P Posted August 9, 2015 Share Posted August 9, 2015 MAP sensor looks fine. All hoses etc where they should be. Suck it and see. By which I mean to suck the end of the MAP sensor hose to check there are no vacuum leaks. Link to comment Share on other sites More sharing options...
listy Posted August 9, 2015 Author Share Posted August 9, 2015 No FCD fitted. I have no time left today so after work tomorrow I'll pull the plugs. Link to comment Share on other sites More sharing options...
listy Posted November 16, 2015 Author Share Posted November 16, 2015 Well, I've managed to check absolutely nothing due to another incident involving a CAT Digger and my front wing. Can someone remind me the best way to check the fuel pump? Iirc turn the key to the last position (before turning over) and you should be able to hear it prime? What sound am I looking for? Link to comment Share on other sites More sharing options...
RobUK Posted November 16, 2015 Share Posted November 16, 2015 You can bridge 2 pins in the diag port to turn the pump on, can't remember which though Link to comment Share on other sites More sharing options...
Chris Wilson Posted November 16, 2015 Share Posted November 16, 2015 I *THINK* it's B+ and FP but I have been to the pub... Link to comment Share on other sites More sharing options...
Scott Posted November 17, 2015 Share Posted November 17, 2015 As above, it's B+ & FP. They're pretty close to each other (1 pin between). Link to comment Share on other sites More sharing options...
listy Posted November 17, 2015 Author Share Posted November 17, 2015 Thanks guys. Hoping to have a look this week so when it comes back from being repaired after the builder incident I can crack on and get her running again. Link to comment Share on other sites More sharing options...
