supra_ufo Posted July 24, 2015 Share Posted July 24, 2015 Can anyone who has recently bought longer wheel studs please send me a link or provide some information on where to buy? They are for the front wheels. Length wise I am looking for around 63mm ones (I want to use a 10mm spacer). I did buy some from Demon Tweeks but they were off by a touch and are not properly going into the back of the hub for a flush finish. Quote Link to comment Share on other sites More sharing options...
manny Posted July 24, 2015 Share Posted July 24, 2015 I used H&R studs, it was cheaper to buy a spacer kit with studs than buy the studs on there own. They fit perfectly and are TUV approved so should be decent quality. I think I bought them from Eurocarparts but can't be sure. Quote Link to comment Share on other sites More sharing options...
RobertG Posted July 24, 2015 Share Posted July 24, 2015 I bought these and they fit perfect, super fast delivery too Quote Link to comment Share on other sites More sharing options...
supra_ufo Posted July 24, 2015 Author Share Posted July 24, 2015 I used H&R studs, it was cheaper to buy a spacer kit with studs than buy the studs on there own. They fit perfectly and are TUV approved so should be decent quality. I think I bought them from Eurocarparts but can't be sure. I asked performance alloys, H&R they dont do a 10mm hub centric spacer...(even though there site says it does) I did not ask them for studs though Robert, do you have any photos of them? Quote Link to comment Share on other sites More sharing options...
a98pmalcolm Posted July 25, 2015 Share Posted July 25, 2015 H&R spacers on mine. And they came with studs Quote Link to comment Share on other sites More sharing options...
Rob W Posted July 25, 2015 Share Posted July 25, 2015 I'm using Novustech hubcentric spacers with ARP extended wheel studs. Quote Link to comment Share on other sites More sharing options...
baldy Posted July 25, 2015 Share Posted July 25, 2015 I bought these and they fit perfect, super fast delivery too i have used these too, with no issues Quote Link to comment Share on other sites More sharing options...
Justin Bieber Posted July 25, 2015 Share Posted July 25, 2015 I asked performance alloys, H&R they dont do a 10mm hub centric spacer...(even though there site says it does) I did not ask them for studs though Robert, do you have any photos of them? They do, i have them on my car with H&R studs, Ibrar at Speedwells got mine for me Quote Link to comment Share on other sites More sharing options...
supra_ufo Posted July 26, 2015 Author Share Posted July 26, 2015 well the bloke from performancealloys who are a reseller of H&R said they couldnt make them ??? I bought the same ones as Rob and Baldy, lets hope they are ok Quote Link to comment Share on other sites More sharing options...
RobertG Posted July 27, 2015 Share Posted July 27, 2015 Robert, do you have any photos of them? Here you go mate Quote Link to comment Share on other sites More sharing options...
supra_ufo Posted July 27, 2015 Author Share Posted July 27, 2015 they look exactly like the ones I got Only went in as far as this... Quote Link to comment Share on other sites More sharing options...
thomo8568 Posted July 27, 2015 Share Posted July 27, 2015 Looks like you need to put something under the nut. So you can pull them through. As looks like you've run out of thread to tighten it down on. Quote Link to comment Share on other sites More sharing options...
supra_ufo Posted July 27, 2015 Author Share Posted July 27, 2015 No mate, I had 2 washers and two nuts on top of that, that last pic I was removing is deceiving... Quote Link to comment Share on other sites More sharing options...
Mk4Gaz Posted July 27, 2015 Share Posted July 27, 2015 They will go in, I've been fitting mine this afternoon. You just need to keep turning them in. I'll get a picture of how I've been doing it, believe me, they will go! Quote Link to comment Share on other sites More sharing options...
supra_ufo Posted July 28, 2015 Author Share Posted July 28, 2015 If you say so Gaz, like I said I used the power of gray skull!! Quote Link to comment Share on other sites More sharing options...
Mk4Gaz Posted July 28, 2015 Share Posted July 28, 2015 Lol, he man! I'll be doing my osf tonight, so I'll get a couple of pics, and upload them. I found they got tight about half way in, but they do go Quote Link to comment Share on other sites More sharing options...
Iky Posted July 28, 2015 Share Posted July 28, 2015 Lol, he man! I'll be doing my osf tonight, so I'll get a couple of pics, and upload them. I found they got tight about half way in, but they do go How are you holding the hub Gaz? Did you feed the studs through and put the disc & caliper on and then tighten them whilst on the brakes? Quote Link to comment Share on other sites More sharing options...
Mk4Gaz Posted July 28, 2015 Share Posted July 28, 2015 No mate, I have a long levering bar (about 600mm), and I wedge that between two studs and the floor. This stops the hub moving, whilst pulling the new stud in Don't bash all the studs out, do one at a time, other wise you'll have all kinds of grief trying to hold it still! I'll get a photo this eve, when I carry on, and you'll see. Probably about half 5 ish Quote Link to comment Share on other sites More sharing options...
baldy Posted July 28, 2015 Share Posted July 28, 2015 use a lubricant a couple of washers and just keep winding through. you dont want them falling in the hole else they'll spin the spline when trying to get your wheels off Quote Link to comment Share on other sites More sharing options...
Chris Wilson Posted July 28, 2015 Share Posted July 28, 2015 If you use a hammer to bash them out expect to be replacing the hub bearings very soon. The hardened steel balls will indent the bearing tracks and the bearing will soon fail. remove the hubs, press out the old ones, press in the new ones. Those studs are appalling anyway, there should be a plain shoulder all the way through the spacer and no more thread than needed to effect a clamping force. Not that spacers are a good idea in the first place. Pulling them in with nuts will probably stretch the studs. If you need much more torque on the threads to pull them in, than is recommended for final tightening, you are over stressing the studs before you start. If you are using all the force it seems you are, God knows what stretch load is on them. If you simply MUST do it this way you need a roller thrust bearing under the nut to remove face friction, so most effort is pulling, not just turning the nut against face friction. But REALLY you should be pressing them in and out... Quote Link to comment Share on other sites More sharing options...
Mk4Gaz Posted July 28, 2015 Share Posted July 28, 2015 Here's my home method, and it works quite well. I wouldn't say the bolts are under extreme stress, as I'm not having to use loads of force on the ratchet. The old studs tap out really easily, I'm only tapping lightly. Best to use a bit of penetrating gear around them first - I make my own stuff up, using a 50/50 mix of acetone and power steering fluid. It's something I picked up years ago, don't ask me how it works, but it does! Supra extended wheel stud fitment: Quote Link to comment Share on other sites More sharing options...
supra_ufo Posted July 28, 2015 Author Share Posted July 28, 2015 Cheers Gaz, im going to give this another go tomorrow thanks for the video, that will help loads Quote Link to comment Share on other sites More sharing options...
jim Posted January 14, 2016 Share Posted January 14, 2016 I need some extended studs, and was going to order the ones in Robert's earlier post. Any update from people who have used them, have they been ok? Quote Link to comment Share on other sites More sharing options...
