TheTurtleshead Posted July 24, 2015 Share Posted July 24, 2015 Used but in fine fettle. I ended up changing this as I thought that it was at fault for the clutch failing to disengage. When my new clutch also would not disengage it became clear that there was nothing wrong with this one. If I hadn't believed this was at fault I'd never have changed it out, it's a brilliant clutch! It held 660ft/lbs and 708HP on my car, with a standard 6 speed driven plate. The only sacrafice you have to make over a stock clutch is 130% pedal stiffness, so 30% stiffer than stock. Trust me, it's not that bad, you get used to it and forget about it soon enough. It has 100% stock engagement, and is 100% quiet as it uses the OEM Dual Mass Flywheel. So no juddering and no rattling! Truly a great clutch for a single supra. Condition; Cover plate- Some superficial marks, good working order. Driven plate- Used but I bought it new. The friction plate hasn't even worn across 100% of it's face yet as you can see in the pictures. Loads of life left yet! £250 + post or collection for a 700HP capable clutch setup... Bargin! Link to comment Share on other sites More sharing options...
TheTurtleshead Posted July 29, 2015 Author Share Posted July 29, 2015 Bump! Surely someone is going single and wants a bargain clutch? Link to comment Share on other sites More sharing options...
TheTurtleshead Posted August 5, 2015 Author Share Posted August 5, 2015 Bumpington! Link to comment Share on other sites More sharing options...
TheTurtleshead Posted August 12, 2015 Author Share Posted August 12, 2015 Buuuuummmppp! Link to comment Share on other sites More sharing options...
TheTurtleshead Posted August 12, 2015 Author Share Posted August 12, 2015 The rattle from my LA twin with lightweight flywheel is a bit annoying, genuinely so much nicer with a DMF and this fitted! If I hadn't sold my almost new DMF I'd probably change it back! Link to comment Share on other sites More sharing options...
2JZ inside Posted August 12, 2015 Share Posted August 12, 2015 Just out of curiosity what sort of rattle noise do you experience and when / what rpm range ? I bought the car with aftermarket flywheel and paddle clutch and it seems to make rattling noise on low rmp's up to 2000 not sure if it's the clutch or flywheel which makes noise. Link to comment Share on other sites More sharing options...
Dim Sum Posted August 13, 2015 Share Posted August 13, 2015 Just out of curiosity what sort of rattle noise do you experience and when / what rpm range ? I bought the car with aftermarket flywheel and paddle clutch and it seems to make rattling noise on low rmp's up to 2000 not sure if it's the clutch or flywheel which makes noise. That be the flywheel. I have the the RPS street clutch max like TheTurtleshead but I also install the RPS Cyn-R-G Segmented Flywheel which is causing the noise you are referring too. I am planning to change it back to the stock OEM flywheel to remove the rattling. I recommend this clutch. Link to comment Share on other sites More sharing options...
2JZ inside Posted August 13, 2015 Share Posted August 13, 2015 Thanks. Link to comment Share on other sites More sharing options...
TheTurtleshead Posted August 27, 2015 Author Share Posted August 27, 2015 Still here! Link to comment Share on other sites More sharing options...
TheTurtleshead Posted September 9, 2015 Author Share Posted September 9, 2015 Anyone? Can drop to JAE..! Link to comment Share on other sites More sharing options...
SilentAgro Posted April 5, 2016 Share Posted April 5, 2016 Do you still have this clutch? I have one in my car at the moment and like it a lot. Don't see many of these around now? Link to comment Share on other sites More sharing options...
TheTurtleshead Posted April 5, 2016 Author Share Posted April 5, 2016 Long sold now! Yeah it is a nice clutch, tiny bit heavy, but worth putting up with as it retains the oem DMF so is perfectly quiet. Using it with a stock full face disc means it's nice and smooth with no engagement judder. Link to comment Share on other sites More sharing options...
SilentAgro Posted April 5, 2016 Share Posted April 5, 2016 I have a lightened flywheel of some sort. It works well for me though. Can you get these new? Link to comment Share on other sites More sharing options...
