Planning my single build - Parts list and questions
Big Mark
Still early day, so just gathering info and opinions.
I was under the impression that to get the most out of a greddy style manifold it was better to use a 90mm throttle body such as the Q45? Though I did see a guy in america use a 90mm drive by wire LS3 throttle body, looked like a neat install too. http://www.mkivsupra.net/vbb/showthread.php?324819-Drive-by-Wire
Thanks Chris but I'd rather get the engine right, with a spec that ticks my boxes and deal with the transmission when required. I've already factored in the need for an upgraded autobox, probably from SRD.
As for Turbo I'm open to as much advice as possible about which to go for. I merely mentioned the PT6062 GEN 2 as a lot of people rate it's bigger brothers the 6266 and 6466, so figure as the newest and smallest GEN 2 turbo from PT it'd be the right size for my goals.
Jekyl made 385hp with OEM 330cc injectors. Load's people people these days making 1hp per cc. 680cc injectors on stock pressure 40 psi for 600hp is 88% duty cycle if you go 1hp - 1cc. with an extra 2psi fuel pressure his new injectors are rated safely at 700/720cc. That's then at 85.71%.
So if between your advice of 80-85% he isn't that far off when you calculate it out.
Found this link today regarding injector sizing... http://www.supraforums.com/forum/showthread.php?564330-Injector-sizing-guide
