Priming Turbo's After Replacement
Timlowthian
Hi all,
Almost finished replacing the turbo's on my supra and wondered about the procedure for priming them with oil so they don't run dry on the first start up.
Is it a case of stopping the fuel pump and turning it over so the oil circulates?
If so which fuse is it to stop the fuel pump starting?
When I did mine I just took the lead off the ignitor and turned the ignition over until the oil light went out then let it rest for a few mins then did the same again then fired it up the third time and left to tickover.......this was OEM twins that had been used before but had then been sat dry for a while (a few weeks) ....ie not brand new dry turbo's.
I also use this method when ever the motor has been sat for a while, just let it turn over on the starter without firing up.
You`d better make sure your battery is fully charged up then cause that baby is gona be doing some cranking over and then some...:)
