Zunsport Grille
Claire Helen
Hi,
Apparently being a member of this forum means you can get a discount on the Zunsport Grille's on Ebay? Anyone else heard of this and/or have a code that I need to type?
This is the one I want :)
http://www.ebay.co.uk/itm/ZunSport-Toyota-Supra-MK4-1993-1998-Black-Steel-Mesh-Lower-Centre-Grille-/201195938276?pt=LH_DefaultDomain_3&hash=item2ed83661e4
Thanks
Hadn't heard of it and was going to point you in the direction of your membership number to see if that worked, but apparently there is a discount, see this thread for the code :)
http://www.mkivsupra.net/vbb/showthread.php?236122-15-or-20-off-Zun-Sport-grilles&highlight=zunsport+discount
Thank you :D Saved me £15 which is better than nothing :)
Guest markolambo
Hi, i have the Zun Sport grille fitted to of my supras looks great and is easy to fit... note that you need the centre and the two fog light areas...see attached pdf picture of it fitted[ATTACH]2703424[/ATTACH]
The picture is silver i note the one on ebay is black which was an extra £20
New Doc 36-1.pdf
Edited by markolambo (see edit history)
