Kaan's SRD built Supra,, the end result.!!
Kaan W
Well.... It's been a long journey but here it is, the SRD1000s.
I met Lee and Ryan this morning at Abbey Motorsport hub dyno for what was the day to put all the hard work and craftsmanship to life.
The car was put in place and bolted to the dyno then the mapping began, first few runs we reached 824.5 RWHP at 7600rpm on Vpower @ 1.7 bar of boost. All seemed well the gearbox held strong so it was time to push it further.
We then run a 70% ethanol mix which we then reached the overall figure and maxed the turbo out at 906.7 RWHP @1.8 bar of boost at 7300 rpm which I believe is well over 1000hp at the flywheel ;)
The transmission has held up incredibly well for a built a340 and feels strong throughout the rev range. With the Syvecs now controlling the transmission as a standalone it's able to lock the torque convertor up and have full control at each rpm enabling a safe load on the gearbox.
I would like to say a big thank you to everyone involved at SRD and the man himself Ryan G for the mapping. I'm absolutely over the moon with the result and wouldn't have done anything differently.
I've had the car out on the roads and it pulls very strongly! A lot more than I expected, the mickeys put down the power so well it pins me to the seat in every gear!
Well done guys you've made what seemed at the start impossible and made it a reality you should be very proud of!
V-Power @ 1.7 bar -
824.5 RWHP at 7609 rpm
673.0 Ft Lbs at 5492 rpm
V-Power @ 1.8 bar with 70% Ethanol -
906.7 RWHP at 7300 rpm
711.6 Ft Lbs at 6288 rpm
http://www.mkivsupra.net/vbb/attachment.php?attachmentid=203442&d=1437503324
http://www.mkivsupra.net/vbb/attachment.php?attachmentid=203393&d=1437432037
http://www.mkivsupra.net/vbb/attachment.php?attachmentid=203394&d=1437432097
Edited by Kaan W (see edit history)
[/url](can a moderator please embed this I'm having trouble).
As it is in the SRD section, it has to be Lee to do it - we can't edit posts in this section :)
As I said on facebook and on your other thread, incredible results Kaan! Totally chuffed for you. Very impressive :thumbs:
Ah fair enough he's done it anyway :)
Thanks very much.!
Nice work :cool: could someone post up the dyno graphs? :)
It's at the end of the video :)
