Acton Posted July 19, 2015 Share Posted July 19, 2015 '93 j-spec auto N/A I've noticed over the last couple of days that when my engine has been running for a while, I get a really noticeable wirring noise when I turn the wheel but also driving in a straight line and accelerating I get the same buzzy/ wirring noise. The level of fluid was fine. Am I going to need a new pump? Quote Link to comment Share on other sites More sharing options...
rider Posted July 19, 2015 Share Posted July 19, 2015 The PS fluid should be a nice and clean. I had a noticeable notchiness in my power steering and the oil smelt a bit off so a change and all was well. Draw a bit of oil out and check it looks and smells good as a change out would be the cheapest solution to any problem. Quote Link to comment Share on other sites More sharing options...
Acton Posted July 19, 2015 Author Share Posted July 19, 2015 I'll drain and refill next week then. Keep my fingers crossed that helps Quote Link to comment Share on other sites More sharing options...
Chris Wilson Posted July 20, 2015 Share Posted July 20, 2015 Take the reservoir off and wash it out *WELL* with petrol or brake cleaner. Then blow out with compressed air and wash out again. There's a nylon gauze as a filter near the bottom of it . DO NOT POKE AT IT, you'll easily puncture it!! They clog up with sediment and the pump cavitates and makes a noise such as you describe. Similarly if the suction hose from pump to reservoir is hard and leaky, or the O ring on the pipe adaptor to the pump body is hard, the pump can draw air and make a noise. Either situation will slowly erode the pump body and vanes, making a rebuild very costly. So it needs fixing ASAP. Quote Link to comment Share on other sites More sharing options...
Acton Posted July 21, 2015 Author Share Posted July 21, 2015 Take the reservoir off and wash it out *WELL* with petrol or brake cleaner. Then blow out with compressed air and wash out again. There's a nylon gauze as a filter near the bottom of it . DO NOT POKE AT IT, you'll easily puncture it!! They clog up with sediment and the pump cavitates and makes a noise such as you describe. Similarly if the suction hose from pump to reservoir is hard and leaky, or the O ring on the pipe adaptor to the pump body is hard, the pump can draw air and make a noise. Either situation will slowly erode the pump body and vanes, making a rebuild very costly. So it needs fixing ASAP. Thank you for that advice. I've stopped using the car as soon as it started, so I don't exacerbate the problem until I find a solution. I will give this a go at the weekend. Thank you Quote Link to comment Share on other sites More sharing options...
