Single installation question
thak1lla
Hi guys, been a members for a long time here, just decided to change my twin for a single 6465, twin are removed but now I can't find a post with valid picture of what to remove or not! In most of the post the link are broken...so here it is...
1- Attach turbo oil line to here?
Plug back to the heater? and block the small one? right?
Block this oil pass?
Use this oil pass for turbo?
Remove the hose and put a small air filter? is that right?
Found this near the alternator...anyone know what it is?
Thats about it, just wanna be sure I do it right! thanks guys
- - - Updated - - -
i know my engine is dirty...will fix that this winter :p
6 looks like the wires to your crankshaft position sensor, minus the plug... Did you destroy it when removing the twins?
Yep, the terminal shell is missing, they are the terminals from the crank position sensor. You can buy a new shell from Toyota if the terminals are undamaged. You can buy terminal repair wires too, if they are damaged.
thanks guys I will fix that soon im currently installing the single, almost everything is bolted in place, was wondering if I can vent the wastegate without the tube? cos its in the way with the downpipe.
No, not unless you want a fire somewhere in your engine bay!
You'll need to get a custom downpipe and/or screamer pipe made bud
