Mad Hatter Posted July 17, 2015 Share Posted July 17, 2015 as heading, still only 0.8 bar?... haven't hit a fuelcut yet so feel no need to add the FCD. might bleed some boost off or remove the ring and see what happens. good, bad, opinions please? Quote Link to comment Share on other sites More sharing options...
safcdixon Posted July 17, 2015 Share Posted July 17, 2015 Boost leak? Might be worth taking the ring out and giving it one run to see if it hits cut, bit crude but you will get an answer of whether you ring is too small haha Quote Link to comment Share on other sites More sharing options...
Mad Hatter Posted July 17, 2015 Author Share Posted July 17, 2015 i've run it in linearTT and pushed 1.2-4 happily. back to stock vsv setup and 0.8 regardless of cats... weird. Quote Link to comment Share on other sites More sharing options...
safcdixon Posted July 17, 2015 Share Posted July 17, 2015 Vsv/s must be goosed then bud, have you had them tested or tryed them on another supra too test that they work Quote Link to comment Share on other sites More sharing options...
Mad Hatter Posted July 17, 2015 Author Share Posted July 17, 2015 second turbo wouldn't come on it the vsv's were duff?... turbo transition is really good and i cleared all the lines when going back to stock Quote Link to comment Share on other sites More sharing options...
