Question for the Auto guys.
tony tt
The logs are fine apparently with Ryan. I'm not sure staying in 4th till stop is right though. It doesn't select 2nd till I try accelerate it just stays in 4th Then plays catch up after its laboured for 10ft or so. OD off is sport mode on the Syvecs and it noticeably changes down gears under 30mph. With OD on its comfort mode almost with smooth changes etc. ryan is tweaking economy mode for it to be changing down like sport mode under 30.
There is no way pulling away in 4th for 10ft is correct, glad he is making the changes to drop them , like I said before they do stay in 4th until they stop but come out straight away , or act faster then the syvecs at selecting the correct gear on pull away if ryan has down loaded the toyota auto ecu map?
