Mk4 na's - do they have oil coolers. ?
herbiemercman
do the mk4 na's have an oil cooler and if the answer is no, then would one be advisable post an na/t conversion? as in mid august, courtesy of dr jekyll, i will have my conversion, can't ask dr jekyll at this point in time as he is hard to reach, must be on holiday or up to his neck in work, he is usually spot on with communication.
Edited by herbiemercman
added extra text. (see edit history)
They only have oil coolers when a turbo is fitted ;)
I wouldn't have fitted a turbo kit without one.
TT came with one as standard for a reason.
It's not expensive, so just do it for the good of the engine :cool:
where have you tried to contact me buddy? got no messages
hi craig, sent you a pm last sunday, tuesday and now today, i thought you must be away or some thing, anyway not sure why the pm system is not operating you have always given prompt replies. I have now added your facebook but i think i have all my questions answered, and thanks for that.
your last reply was here below.
To read the original version, respond to, or delete this message, you must log in here:
http://www.mkivsupra.net/vbb/private.php
This is the message that was sent:
---Quote (Originally by herbiemercman)---
---Quote (Originally by dr_jekyll)---
hi buddy.
the ecu has a fcd built in
a boost gauge is nice to have but not essential
a afr again is good to have but not a must.
the mapper will have a boost gauge band afr monitor to map the car after this you should not attempt to adjust the values set. any gauges are purely for monitoring purposes
---End Quote---
Hi Craig,
Very happy with your answer, not long now for my funds to arrive. You really know your stuff and are a good communicator.
I would like you to fit a boost gauge whichever you recommend. Ian.
---End Quote---
Edited by herbiemercman (see edit history)
Only the TT has the oil to water heat exchanger mounted between the oil filter and the block mounting. As stock an N/A does not have this exchanger, which is usually called a Modine, after one of the original makers of them.
:yeahthat:
The NA oil filter neck is also a nice mod for TT motors if you are removing the stock unit when fitting another cooler instead ;)
No worries, I don't think an oil to water heat exchanger was even an option on the N/A, at least I do not recall ever seeing one.
Hi Chris, Your on it as usual, a lot of things i am finding on the site is based on different experiences and you tend to stick to the basic tech info, many thanks.
I am having a NA/T conversion in mid to late August with Craig, (Dr Jekyll), he has many successful conversions under his belt and comes well recommended, good replies etc to tech questions and very competative costs.
I will see what he thinks re an oil cooler, thanks for your help. herbiemercman.
